First post, by Rhuwyn
I've never gotten very much into Single board Computers. I've only done some work on ones that were already built. I came accross a deal for a passive backplane in a fairly compact chassis. It has 3 PCI and 4 PISA slots. the PISA slots are confusing to me. All I can find is that many of the Single Board Computers require the PISA slot. If you can ONLY use it for that however then why are there four of them? I also read that it has the ISA signels on the top edge and the PCI signels on the bottom edge so does this mean I can use either a ISA or a PCI card in these slots as well as the actual SBC?
Also, would an older ISA SBC work in a PISA slot?
Any other general knowledge about SBCs and their backplanes I should know before attempting anything?
