First post, by dnewhous
I see that Windows Me came with DirectX 7.1 and was updated to DirectX 9.0c. It came with IE 5.5 and could be upgraded to IE 6 SP1. The best Intel CPU at the time Me was released was the Pentium 4 Willamette Socket 478 and at the time DirectX 9.0c came out it was the Pentium 4 Cedar Mill LGA 775 with the max speed of 3.6 GHz. Anyone thought of making WindowsBox?
Also, might need Outlook Express 6 SP1 and Windows Media Player 9.
Daniel L Newhouse
Reply 1 of 15, by leileilol
At that point you're better off wrapping a few libraries (dgvoodoo2, indirectsound et al), since WinMe's era was already quite well standardized, short lived, and intertwined with the early XP era which is already (mostly) compatible with modern-day Windows anyhow. A fully blown emulator would be a waste for this part at this current time.
though there is PCem, but that's only useful for up around later 2000 when basic Voodoo support was finally shedding in mainstream pc gaming
Reply 2 of 15, by brostenen
There are still pletifull of hardware around, that are WinME compatible.
Reply 3 of 15, by Jorpho
No, you are the first one, the visionary genius we have all been waiting for who will lead us out of creative darkness. 😒
Reply 4 of 15, by Trank
I actually 🤣'd.
Reply 5 of 15, by dnewhous
I would add that the best Glide API card should be emulated, the never released Spectre 3000.
Also, I think Pentium 4 is also probably overkill.
System requirements for running Windows ME[50]
Minimum Recommended
x86
CPU Pentium, 150 MHz Pentium II, 300 MHz
Carmageddon II: Carpocalypse Now System Requirements
Intel CPU
Pentium III
So,
Tualatin 0.13 µm 700–1400 MHz 512 KB 100–133 MHz Socket 370, BGA2, µPGA2
Did the Tualatin PIII ever get released?
Daniel L Newhouse
Reply 6 of 15, by leileilol
Camra2 predates Pentium III by many months.(and doesn't really require it, not for speed nor for sse - it's quite capped and ran roughly the same everywhere iirc)
where are you getting your information from
Reply 7 of 15, by SRQ
PC-EM can do 95 I think? It can emulate a Voodoo 2 now so that's pretty dangcool.
Reply 8 of 15, by Jorpho
What makes you think anyone will be able to emulate hardware that no one has ever seen and for which no drivers or other publicly available software exists?
If the card is merely like a very fast voodoo 2, then existing solutions are entirely adequate.
Reply 9 of 15, by dnewhous
They could have a prototype lying around still. Better yet, a version control system with the Cadence design!
I am getting my information from the wikipedia mostly.
https://en.wikipedia.org/wiki/Pentium#Pentium_4
https://en.wikipedia.org/wiki/Windows_ME
https://en.wikipedia.org/wiki/3dfx_Interactive
http://www.game-debate.com/games/index.php?g_ … pocalypse%20Now
https://msdn.microsoft.com/en-us/librar ... ed.5).aspx
Daniel L Newhouse
Reply 10 of 15, by keenmaster486
This is far, far harder than you think it is.
World's foremost 486 enjoyer.
Reply 11 of 15, by leileilol
IIRC the unreleased 3dfx Napalm wasn't a Glide-supporting card in the state it was left in and it's pretty fruitless to emulate an obscure prototype as an end-all solution. Preservation maybe, but not for the prospect you're asking for
all strange requests from a 2002 account, so i'm going to guess it was a really heavy rock. or jail, so i'll fill you in on a little secret from the past 10 years of great technological advancement:
virtualization extensions in modern CPUs and motherboards
You can virtualize a Windows XP VM in VirtualBox/VMWare at full speed with modern 3d accelleration. It's not ME, but why would anyone want that?
Reply 12 of 15, by dnewhous
In my experience glide API games need to be run in glide API mode or they stink.
Glide API games do not work in XP without a patch.
Glide API games want PIII not PII.
Daniel L Newhouse
Reply 13 of 15, by leileilol
Glide games don't really care what CPU you run them on as long as it can execute the driver. and plus there's nice glide wrappers to use with modern hardware if you really desire glide games specifically on a very wide range in generations of video hardware..
Also the "they stink" only really applies to UnrealEngine1 games which had some differing texture combine behavior than the (then unfinished) Direct3D/OpenGL renderers they had. All else is preferences, performance (certain cpu/3dfx combinations), and quality placebo from the dac filter/defaultgamma
Most "xp patches" are nvidia compatibility patches, or kernel-related/appcompat workarounds, and has less to do with using Glide. also breaking news: there's 3dfx card drivers for 2k/XP that support Glide.
Reply 14 of 15, by dnewhous
In my experience the glide API wrappers don't work when using a racing wheel and a keyboard at the same time. However, if those wrappers are close to the mark, it's DirectX 8.1 that would do the best job imitating the Glide API.
Also, Quicktime 6.5.2 was the version for Windows Me. Anyone know what version of iTunes that was?
Daniel L Newhouse
Reply 15 of 15, by Jorpho
There is no reason the glide API wrappers should be at all affected by the presence of a racing wheel.
DirectX is backwards-compatible, at least as far as 8.1 is concerned. If a wrapper needs to use some DirectX 8.1 function for some reason, there is no reason it cannot do so if DirectX 9 is installed.
What does that matter? If you need Quicktime for a certain game, then it is best to stick with whatever version of Quicktime that game required, or to use Quicktime Alternative instead. Quicktime is an ugly, bloated mess. Anyway, I think versions that old were still distributed independently of iTunes.
