Bought a 486
First post, by xjas
Ten bucks, couldn't resist. Here it is:
139.72 KiB
Wait a minute...
Did you see it yet?
184.47 KiB
111.85 KiB
Here's the back:
159.39 KiB
Yes, this is one of Apple's many experiments in the '90s to give their machines just that little bit more widespread appeal. Note that it does not have an x86 "compatibility card", rather a complete x86 PC on the same motherboard. Which, in lovely '90s Apple fashion, slides out with just two clips & two screws:
368.64 KiB
Apparently some of these came with an Intel DX2/66 and some of them came with a Cyrix, and some of them ran the 486 at 70MHz. I didn't pry the heatsink off yet so I don't actually know which one mine is. Mine is the LC630 which means it has a 68LC040 with no FPU but you can upgrade that to a full-featured 040, which makes it identical to a Performa 640. Apple. why u do this ??
Reply 1 of 5, by xjas
I had a look for bulgy caps but I actually don't see any of the typical electrolytic type caps at all. Here's the underside of the board:
443.93 KiB
Note the three separate SIMM slots - one main one for the system RAM (there's also a few MB soldered onto the motherboard), a proprietary Apple one for cache, and a third one on the riser board for the 486 - empty here because it's completely optional. You can happily divide the main RAM between the Mac & x86 at will.
396.78 KiB
Some quick research told me this thing has a "Soundblaster compatible" sound card for DOS stuff. Well, no, it has a genuine Vibra16 with a real goddamn OPL3 chip and an actual MIDI port. Yeah, was pretty pleased to find that when I took it apart.
352.36 KiB
The sound card is actually a beautiful bit of bizzarechitecture. That 15-pin MIDI/gameport is exclusively for DOS software, Mac MIDI used the RS422 serial port and joysticks at the time were ADB. Well, the gameport is on its own card on the PDS slot which is the direct bus to the 68040 (e.g. equivalent to VLB.) Madness:
114.56 KiB
Anyway my "vintage Mac" table is getting pretty full but I'm pleased with this latest addition. 😎 It'll be a fun little fixer-up project.
Reply 2 of 5, by chinny22
That's 5 bucks a computer! good deal, no matter how you look at it.
Will be interesting to see how it performs in benchmarks against a dedicated PC
Reply 3 of 5, by Tetrium
That's a very interesting find actually, never knew these existed.
My retro rigs (old topic)
Report spammers here!
