First post, by vladstamate
Hi,
I got a P4 (2.66 Ghz) system. However it is from Europe and I am in US) and the power supply is missing the 110/220 switch. It originally had a 350W power supply. What is generally required for such a system? I will eventually put some kind of AGP card in it.
YouTube channel: https://www.youtube.com/channel/UC7HbC_nq8t1S9l7qGYL0mTA
Collection: http://www.digiloguemuseum.com/index.html
Emulator: https://sites.google.com/site/capex86/
Raytracer: https://sites.google.com/site/opaqueraytracer/
Reply 1 of 3, by Jade Falcon
Rank BANNED
BANNED
The psu may have a active power switching. Give it a try on 110v also what's its model?
Wile not necessarily required. I'd unplugged the psu from the system and ground the green wire form the motherboard.
That all aside I'd go for a newer 450w psu in a p4 system.
Reply 2 of 3, by matze79
If 110V applied to 240V Supply, shouldnt it simply not work in baddest case ?
Reply 3 of 3, by chinny22
Doesn't matter where in the world it is from, power requirements wont change. 350w is a 350w on the PC side, its just expecting a different voltage from the wall.
That said if you want a rough idea you can find many power supply calculators on the interent
http://images10.newegg.com/BizIntell/tool/psu … tage-Calculator
PS
Never done it the other way round but I know from experience that supplying 240 to a 110v power supply kills it, and again 5 years later, same result! 😊
