First post, by Niezgodka
Niezgodka
Offline
- Member
Recently I tried to make DOS gaming machine - P100Mhz.
I have installed Gravis Ultrasound - works great!
Than I added AWE64Gold (Pn'P version). Initially I installed drivers, everything works great. I tried to modify the Autoexec, now I got
Creative Plug and Play Configuration Manager (v1.06)...Your system configuration has changedPlease run Windows 95 to initialize your system configuration
So I put bat and config, before I edited it. Same thing (?)
Funny thing, when I execute ctcm after booting - it takes it, and system assign irq, dma... etc.
What is wrong with it? I remember installing SB back in the day as a simple task.
What would be optimal combined GUS and AWE64 autoexec lines? Is there an order for it? They should be initiated at very beginning of autoexec, or it does not matter?
Can you provide some examples of your GUS AWE configurations?
