First post, by clueless1
Is there something special about this card that the 4.13.7192 drivers won't work with it? I ended up googling "ATI Rage 128 GL PCI drivers" and came across some random driver site that had a driver archive called 'Win98.zip". They turned out to be version 4.11.6110 and they worked perfectly. Great, but I wonder what is the latest driver that works with this card, without having to test all of them manually. 🤣.
Reply 1 of 8, by Jo22
ATI's GL series were made for professionals (CAD/CAM and so on). Perhaps it has a different ID because of this and only certified drivers will work with it.
Anyway, I don't know of the latest drivers either. I hope someone can help us (another Rage 128 user here!) 😀
Reply 2 of 8, by clueless1
Interesting, thanks for the info Jo22. All I'm doing at the moment is benchmarking, so I'll make do with the 4.11.6110. But for the record, here's what happens when I try to install the 4.13.7192 drivers:
-the install completes, I reboot the PC, and it hangs at the Win98 splash screen. If I reboot to Safe Mode and go to Device Manager, it says my video card is an Xpert 128. So that is what the 7192's are thinking this card is.
I used Speedsys to ID this card as "Rage 128 GL SD" which I'm guessing is short for SDRAM.
Reply 3 of 8, by Jo22
You are welcome! 😀 Wait, here's a link..
ATI RAGE 128 Next Generation 3D and Multimedia Accelerator
("RAGE 128 GL for OpenGL Workstations and high-end entertainment PCs")
http://dmarton.tripod.com/rage128.htm
Reply 4 of 8, by synrgy87
There are so many variants of the Rage 128 cards out there, was a pain getting on 128 pro ultra 32mb working, eventually got working drivers from dell, but still had to do a little edit to one of the files, the card has a different vendor / device id that isn't covered by the official drivers, so they'd not work.
Reply 5 of 8, by clueless1
Turns out the Rage 128 GL PCI is pretty slow. A lot slower than the Rage 128 Pro AGP. 😲
3dmark99 1024x768x16bpp: Pro-4246; GL-3186
3dmark99 1024x768x32bpp: Pro-3150; GL-1572
Reply 6 of 8, by Aeridyne
You don't happen to have those drivers still do you? The 4.11.6110?
I can't find them anywhere and have the exact same issue, hangs on slash screen at reboot. I've tried about every other driver imaginable for this Rage 128 card that I have.
Have been sitting on this card for years unable to find a working driver for it.
Reply 7 of 8, by zyga64
I also have Rage 128 GL PCI and this driver version is working for me: W98_R128_4_12_6269_EN.exe
Download from Soggi's site: https://soggi.org/drivers/ati.htm (rage 128 Win95 section)
8088@8 /640k /Genoa CGA /TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 8 of 8, by clueless1
Aeridyne wrote on 2025-07-13, 09:33:
I just checked through my data archives and could not find it. Hopefully Zyga64's driver will work for you.
