First post, by 386SX
Hi,
did anyone ever test this cpu on a 386DX motherboard? With a 33Mhz clock it's really running at 66Mhz? And what about the 40Mhz only motherboard?
Thank
Hi,
Thank
Here are some benchmarks of this chip (see several posts from skv400):
Post your 386 Speedsys results here
Anyway... if you're lucky, on 40MHz it will run at 80MHz... but that's quite a long shot as Cyrix DRX2 is 5V cpu. Your motherboard should have a 80MHz oscillator which can be replaced for a 66MHz part. Some mobos have jumpers for setting motherboard clock/speed.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
wrote:Here are some benchmarks of this chip (see several posts from skv400):
Post your 386 Speedsys results hereAnyway... if you're lucky, on 40MHz it will run at 80MHz... but that's quite a long shot as Cyrix DRX2 is 5V cpu. Your motherboard should have a 80MHz oscillator which can be replaced for a 66MHz part. Some mobos have jumpers for setting motherboard clock/speed.
Impressive!! Great upgrade for the 386, but I got a Eteq 40Mhz only (sticker) chipset that I think it would not be happy changin oscillator but If I'll get one I'll try.
It's also nice to see that the 386DX-40 itself had some boost from ISA to VLB when you'd think the cpu was the bottleneck.
80MHz is a bad idea. You'll probably just fry the internal cache. Don't risk it with such a rare CPU.
80mhz is suicide don't do it or the internal cache will fail as other people have done it and have regretted it.
I accidentally did this to a Ti 486SXL-40. It runs fine at 2x25, but one time I accidentally left my 66MHz oscillator in and burned the cache. The chip works as long as the cache is disabled.
wrote:I accidentally did this to a Ti 486SXL-40. It runs fine at 2x25, but one time I accidentally left my 66MHz oscillator in and burned the cache. The chip works as long as the cache is disabled.
Understood. I am looking for this cpu I know that it's really rare, hope to find one. At 33Mhz bus if I find a correct motherboard to set it it would be nice to see it running.
You'd probably be better off with a regular 486DLC-40, or a TI486SXL-40 (if you can find one). They're usually a lot cheaper, and provide most of the performance.
