First post, by bluejeans
I want to run doom on its minimum ram requirement but the minimum system ram I can install is 8mb. An unusual request, but will anything be able to do this?
Reply 1 of 5, by Cyberdyne
Ramdrive?
Reply 4 of 5, by keropi
XMSDSK and EMSDSK , resizable/removable ramdisks with the option to load above 16mb, I use it all the time for problematic games: http://www.oldskool.org/guides/oldonnew/resou … es/fu_rd19i.zip
Reply 5 of 5, by konc
You're not just talking about conventional memory but the total right? Otherwise, loadfix is your friend.
