First post, by DOSfan1994
Hey people I am trying a mod trick to get "Half life" to use the voodoo2 card.
(I have moved this post from the Windows forum because it only focuses on more for Windows games on modern systems
It's a trick I found on this forum.
https://www.opengl.org/discussion_board ... on-Voodoo2
It's something like you have into your Windows/system directory and copy the "3dfxVGL.dll" and rename it too "Opengl32.dll" and I need to know what directory I need to put it in.
Reply 1 of 5, by Jorpho
As I said in your other thread:
Just put it in the same directory as your hl.exe (or whatever it is called).
Also, you copied your link incorrectly.
https://www.opengl.org/discussion_boards/show … enGL-on-Voodoo2
Reply 2 of 5, by leileilol
leileilol wrote:
You don't. Half-Life uses the 3dfx MiniGL provided in the gldrv folder. That will use the Voodoo2 card at its fastest and best […]
You don't. Half-Life uses the 3dfx MiniGL provided in the gldrv folder. That will use the Voodoo2 card at its fastest and best.
The thread linked contains crap advice and should not be advised.
NEVER EVER REPLACE C:\WINDOWS\SYSTEM\OPENGL32.DLL
Microsoft made System File Protection a feature in Windows ME for a reason
Reply 3 of 5, by DOSfan1994
Dude what's the point on showing me this "MISSING: Have you seen this game?"
Reply 4 of 5, by Jorpho
That's his signature. It appears automatically beneath each of his posts. You will find similar things on forums all over the Internet.
Reply 5 of 5, by DOSfan1994
Oh I didn't know he had a signature.
