First post, by sean1978
I have a problem, I have a ps/2 model 25-286 with two 16 bit ISA slots. I need 3 slots to run everything I want at the same time.
After looking at a thread about expanding ISA with a passive industrial backplane that plugs into an original ISA slot and connects it to a second board in paralell I had a crazy idea.
Why can't I just piggyback a XT ide card onto my sound card? Basically I attach the card to the backside of my sound blaster and then run wires from the edge connector on sound blaster to the edge connector of the XT ide? Other than it being a bit of a pain why wouldn't it work?
SIMPLETHINGS: Fun stuff from the 80's and 90's!
https://www.youtube.com/channel/UCLxoVzIzuIN1tQ7DRO7gB6g
Reply 1 of 13, by BloodyCactus
sure, it will work if your careful. your just expanding the bus manually like that. just watch out for crosstalk and impedence mismatch etc... or just buy an isa riser / bus extender card on ebay...
Reply 3 of 13, by keropi
I did something similar on my ACER XT when I had it:
I had to use an 8bit ISA riser in order to get flawless operation.
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 4 of 13, by luckybob
I know just how you feel. I had the same issue with my 25.
What 3 cards are you using? I'm only using sound and scsi. I run a scsi > ethernet adapter and that solved the problem for me.
Reply 6 of 13, by luckybob
maybe the ATi VGA Stereo F/X is an option? it is vga and sound on one isa card.
Reply 8 of 13, by feipoa
Scsi to ethernet adapter? What is this?
Reply 9 of 13, by luckybob
Exactly that. Works just like a parallel port one. I recently sold 4 of them on ebay for $90 a pop. Got one left but was planning on keeping it. They work pretty seamless on compact macs. Just like this one: http://m.ebay.com/itm/Dayna-port-SCSI-Link-T- … 2084?nav=SEARCH
Reply 10 of 13, by feipoa
Are there any for Windows? And what speed? Can you use a HDD on the same Scsi adapter simultaneously?
Reply 11 of 13, by yawetaG
Some googling seems to pull up a AMD SCSI to ethernet adapter that was used by HP...
Reply 12 of 13, by Anonymous Freak
It's a plain SCSI device, so no separate device for Windows - it was just commonly used on Macs because they came with SCSI by default. You would need drivers, though, and the only ones I have seen came with Mac drivers. The devices were standard 10-base-T Ethernet.
Of course you can use a hard drive at the same time! That's one of the big selling points of SCSI, you can connect a variety of different devices at the same time. (hard drive, CD-ROM drive, ZIP drive, scanner, printer, Ethernet deivce... I've had all of those connected to a single machine at once.)
