First post, by Ragh
I have the opportunity to buy (cheaply) professional tv monitors from an old tv station. I'd be using them for gaming. Any tips on what should I be looking out for? Thanks!
Reply 2 of 2, by sf78
Check if it has RGB BNC-connectors like this Sony does. Otherwise you are stuck with S-video or composite.
edit: Also note, many of these have mono audio only. You might want to use separate speakers. You should also check if the screen has any burn-in, try to get one without if possible.
    28.24 KiB
