First post, by PcBytes
As the title says,I have a hell of a time trying to get TV output on this card to work.
More exactly,the problem I experience is that no matter what cable I use (no S-Video cable,just two Composite cables,both wired correctly.),I'm not able to get any kind of picture.
First,the two rigs I use:
Main rig - this one is where the one end of the cable goes,into the TV tuner more exactly. It's the one in my signature.
Second rig:
ASRock P4i65G
1GB RAM
40GB HDD w/ 98SE
Winfast A340T GPU
Premier 300W PSU (recapped and improved)
Any ideas? I still haven't found any fix for this,and the "Force TV detection" didn't give any result.
Reply 1 of 2, by Jepael
So from A340T yellow RCA output to tuner AV input, via short AV input to yellow RCA adapter cable?
Reply 2 of 2, by PcBytes
RCA-RCA cable between the A340T and the tuner AV input.
