First post, by Pepo
Pepo
Offline
Hi,
I try dosbox on linux and it works very good. The only mistake is that time on dosbox delays. When I start dosbox time is the same, but after 15 minutes time in dosbox delays more than 20 secondst to linux system time. Can I refresh time in dosbox without restartind dosbox? I try to set cycles to max, but time is still wrong.
