First post, by Smack2k
- Oldbie
Which of these two motherboards would you use to build a 386 - 25 MHZ machine?
DTK PEM 2531D - http://stason.org/TULARC/pc/motherboards/D/DT … -PEM-2531D.html
Biostar MB 1320B - http://th99.classic-computing.de/src/m/A-B/31300.htm
Both have a 50 MHZ oscialator, so 25 MHZ is the most I can use of them without replacing it...
Biostar has a AMD 386 SX 25 MHZ surface mount chip
DTK has an AMD 386 DX 25 MHZ and an Intel 387 Chip Insertion Chips
