FPU 387 questions
First post, by 386SX
Hi,
I found a IIT 4C87DLC-40 I wanted to put on my Eteq based Am386DX-40 system. I didn't remember there was also another one IIT 3C87-40 and I'd like to understand which are the differences? I just know the second is much older version (1988).
Also which software or games (beside Quake) could I try once I'll install it?
Thank
Reply 2 of 25, by 386SX
stamasd wrote:
It reccomends to use the 3C87-40 with the 386DX-40.
I mean, I read the Cyrix DLC having problem with the usual 387 so I imagine the 4C87DLC to be a customized version for the Cyrix but will it work with a Am386DX-40?
Reply 3 of 25, by Anonymous Coward
I am not aware of any incompatibilities between the Intel FPUs and the 486DLC, but what's funny is that certain versions of the DLC don't work with certain versions of Cyrix's own FPUs. No comment on IIT or ULSI.
Sure, the x87DLC badged FPUs might have updates to make them more compatible with DLCs, but I'm pretty sure the main reason they changed the naming scheme is because during the DLC days nobody was buying 386s anymore.
Reply 4 of 25, by 386SX
I was thinking same thing too. 😉
Hope to try soon the speed of 1.5 frame for second in Quake! 😁
Reply 5 of 25, by kixs
In FPU benchmarks there is no difference between IIT 387 and IIT DLC version.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 6 of 25, by feipoa
I have a motherboard which requires you to set a particular jumper if you are using the 87DLC from Cyrix. If you don't set the jumper, it doesn't work. However, I haven't witnessed any speed differences between the Cyrix 387+ and the older grey-top Cyrix 387's. I suspect there may be some fixes for compatibility issues in all the various brands of the 387DLC's for use with DLC and SXL CPUs. I have witnessed some compatibility issues with certain programs when using an SXL2 and the older grey-top Cyrix 387's.
The best I've received in Quake is 3.1 fps with an SXL2-50.
Reply 7 of 25, by nforce4max
Just don't go chasing after the clock doubled versions, not much performance gained and they are crazy expensive.
Reply 8 of 25, by tayyare
My 386DX40 machine is working with an IIT 4C87DLC-40 at the moment. No problems at all (checked with old FORTRAN compilers and other ancient DOS software that utilizes it like matlab, etc.).
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 9 of 25, by 386SX
Great! Which programs or games could I try to test it?
Reply 10 of 25, by tayyare
I really have no idea about any games that works on a 386DX-40 properly and utilizes a FPU at the same time. FPUs were expensive specialized items, and used mainly for ..well, floating point arithmetic. 🤣
I can only suggest AutoCAD (or many other old CAD software), FORTRAN compilers and math software like Matlab, Mathcad, Mathematica, etc. They were the ones I was using during the times.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 12 of 25, by 386SX
Scali wrote:
Falcon 3.0 is a game that can use the FPU, and gives much better performance and enhanced graphics/simulation when an FPU is used.
It made a massive difference for me at the time when I had a 386SX-16 with an IIT387.
It looks like a nice game! 😀
I tested the IIT 387 with Quake to see if it ran ok and .. it run.. 😁
But now I want to test more software on it.. it's nice to have it on my 386.
Reply 13 of 25, by kixs
I don't think Falcon 3.0 ran without a FPU or at least FPU emulator (like q387 or Frankie).
Reply 14 of 25, by Scali
Yes, it has an FPU and non-FPU mode. If you don't have an FPU, certain features are just simplified or not available, and performance is lower.
It was one of the first games to use an FPU. FPUs were certainly not widely available back the (and emulators are too slow, so not an option).
It can also use EMS, which again gives you some improvements in the game (I mainly recall that the videos would play more smoothly with EMS).
Reply 15 of 25, by 386SX
Is it normal that if I disable the Weitek processor enable function from the bios, it says "none" coprocessor at bios post and in the dos programs they see it correctly?
Reply 16 of 25, by Scali
Probably. A Weitek coprocessor is an entirely different beast compared to a 387.
The BIOS POST may just indicate the Weitek setting, while DOS programs actually try to detect a 387 by executing FPU functions and checking if they work.
If DOS programs detect that an FPU is present, it is present.
Reply 17 of 25, by 386SX
Scali wrote:
Probably. A Weitek coprocessor is an entirely different beast compared to a 387. The BIOS POST may just indicate the Weitek sett […]
I never really heard about the Weitek, was that faster?
Reply 19 of 25, by 386SX
gdjacobs wrote:
It was more specialized being optimized for single precision floating point.
https://micro.magnet.fsu.edu/optics/olympusmi … tekmathlow.html
"...Some experts believed that the Weitek silicon devices might have been even faster than the Pentium and some of the other more advanced personal computer microprocessors. However, utilizing system memory meant that an allocation of address space was required to properly use these Weitek coprocessor chips...
