First post, by Hellistor
Hello everybody.
I have searched the local ads a few days ago and I found a Roland SoundCanvas SC-33 Module with power supply. It seems to be in good condition.
The seller asks 30€ for it which I find pretty fair compared to the 80€ plus the other models usually cost around here.
I know it doesn't have the same features as the SC-55. For example only one MIDI connection and no MT-32 support.
These are not really important for me as I'm going to use it on only one machine at a time and I'm gonna use Munt for MT-32 stuff.
Does anybody know how it sounds compared to the SC-55? That's my main concern.
Dual 1GHz Pentium III machine
700MHz Pentium III machine
550MHz PIII IBM 300PL
Socket 7 machine, CPU yet undecided
100MHz AMD 486DX4 machine
Reply 1 of 7, by dreamblaster
no doubt for 30 euro !! get it (if it works)!
https://www.youtube.com/watch?v=sDuSpuL_iBE
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 2 of 7, by Hellistor
Thank you very much!
You're the inventor/designer/maker of the Dreamblaster Wavetable Cards right? If you recommend it, it has to be good! 😀
I'd love to get one of your devices but my budget is really tight right now. I have been dreaming of an S1 or X1 since I found out about them.
Keep up the good work!
Reply 3 of 7, by Kodai
The MT32 support on an SC-55 is rarely ever used for PC games. It was meant for musicians that wanted the basic sound bank but didn't want to deal with a second module. It did not have the ability to receive custom patches like a real MT32/CM32, so it only works for the small base of games that doesn't use custom patches.
The sound quality of the SC-33 is supposed to be cleaner than that of the SC-55. I only have SC-55's so I can't really compare them, but every thing I hear about them is good. I second the motion to get it if it's only 30 euro with power supply.
Let us know how it sounds when you get it hooked up.
Reply 4 of 7, by Hellistor
It took the seller some time to respond but today I have recieved it.
Here it is:
The unit works! I took it apart to check if the battery is fine. It is.
Now I could record some games but thruth be told it sounds exactly like an SC-55MkII. Which means it sounds great!
Thanks for the advice!
Reply 6 of 7, by MMaximus
At the time Roland was expanding the Sound Canvas product line like crazy - they probably had an excess of parts related to the production of Boss drum machines and decided to create a tabletop sound canvas, hence the Roland SC-33 / Boss DS-330.
Here is the Boss DR-660 which looks like a close sibling of the SC-33.
Hard Disk Sounds
Reply 7 of 7, by Hellistor
James-F wrote:
It certainly looks like something from the 80s/90s. 😁
Enjoy!
Thanks, I will!
MMaximus wrote:
At the time Roland was expanding the Sound Canvas product line like crazy - they probably had an excess of parts related to the […]
That looks like it's using the same base chassis, I would not be surprised if you could switch out the baseplate. I also think that's the exact same power supply my SC-33 has.
Makes sense that they used pre-existing parts to make it. I got no complaints, it works great.
