First post, by 386SX
Hi,
I found this motheroard with Nforce430 chipset support AM2 cpu up to 64FX/X2 cpu to build something a bit more modern but as usual, it can't boot. On board there's a Sempron 3200, there're no strange config or jumper to set, I tried two different psu, on board and external gpu, changed bios battery.
Basically the power seems to arrive (power led always on (?)) but the fan don't move, even the psu don't start when the pwr button is pressed. No capacitors are bad and I don't see bad lines or missing components.
What can I try?
Thank
MB: "www.asrock.com/mb/photo/ALiveNF6G-DVI(L1).jpg"
Reply 1 of 3, by TheAbandonwareGuy
386SX wrote:
Hi, […]
Hi,
What can I try?
Thank
Did you try turning the board on without the CMOS battery installed?
Cyb3rst0rm.com: Here There Be Screeds https://www.cyb3rst0rm.com
Reply 2 of 3, by 386SX
TheAbandonwareGuy wrote:
386SX wrote:
Hi, […]
Hi,
What can I try?
Thank
No, I'll try it now.
Reply 3 of 3, by 386SX
No way. The only thing I see is that when you reset the bios the fan moves a bit. But no sign of life. I was expecting to at least switch on the psu or the fan even if was a dead mobo, but never seen a case where nothing start this way.
