First post, by Ampera
- Oldbie
Using a DELL LCD panel, this is probably an exhaustive question, but the interesting thing I have noticed is that when displaying VESA modes of 320x200 or 400x300, it will say in the panel's menu that the video mode is 740x400 or 800x600 respectively, even thought the video mode selected is not. I have tried 3 separate panels and they are all unable to display VESA modes over 800x600, EXCEPT for the mode 1152x864. This mode, for
some strange reason works on all 3 panels.
This mode is only available through the Trio32 (On my Diamond Multimedia Stealth SE) S3 drivers for Windows 3.11 and can not be found on any other systems, not even Win9x (Although it is available on my modern computer). And when looking here: https://en.wikipedia.org/wiki/VESA_BIOS_Extensions it doesn't appear to even be a VESA mode. I don't get it. It appears to be an XGA+ mode though.
I am confused by this, is it the refresh rate that is the issue? It's accepted LITERALLY everything else, and this panel is fairly good with odd refresh rates. Apologies for the tired question, but what could I do to rectify this? This also happens on my Mach64 integrated from a couple IBM servers. On SOME video modes (Not when a proper Linux environment is installed) this happens there too, like when trying to install Ubuntu.
Strange.
