First post, by newoski
Hi Guys,
First post, so go easy. I've put in a lot of time playing around with the parameters in CRT.D3D.fx, including adding // before the Curvature and Distortion fields. However, nothing I try has any effect.
My goal is to remove the curvature, while maintaining the CRT effect.
If someone could post a tweaked fx file or simply instructions for what changes to make, I'd genuinely appreciate it. I'm pulling my hair out!
Thank you
Reply 1 of 2, by maxpacker
#define distortion 0.00
works for me
Reply 2 of 2, by newoski
works for me
THANK YOU!!!!
