First post, by lukeman3000
Edit: Figured out the problem. Doxbox seems to not play nicely with G-Sync. I have a G-Sync monitor and have it enabled. On a whim, I disabled it and the problem was resolved. That said, does anyone know what the underlying issue might be and how to correct it so that I don't have to manually disabled G-Sync every time I want to play a game in Dosbox?
Furthermore, what should my Nvidia control panel settings be for Dosbox? Here's what they look like now:
http://imgur.com/a/Vl48O
I originally noticed this problem while playing Space Quest IV but it has manifested in other games such as King's Quest IV and […]
I originally noticed this problem while playing Space Quest IV but it has manifested in other games such as King's Quest IV and Quest for Glory II. While playing, if I move the mouse cursor the game and the game's audio will stutter. An example can be seen here:
https://youtu.be/k11fjOJLO1g?t=28
I am running Dosbox 0.74 on the following machine:
Windows 10 64-bit
Titan X Pascal
256 GB SSD
8 GB DDR3 RAM
Razer Deathadder Chroma mouse
Razer Blackwidow Chroma keyboard
Dosbox conf file:
# This DOSBox configuration file was automatically created by D-Fend Reloaded.
# Changes made to this file will NOT be transfered to D-Rend Reloaded profiles list.
# D-Fend Reloaded will delete this file from temp directory on program close.
# Command line used when starting DOSBox:
# -CONF "C:\Users\lmill\AppData\Local\Temp\Space Quest IV - Roger Wilco and the Time Rippers.conf" -NOCONSOLE
# Config file for profile "Space Quest IV - Roger Wilco and the Time Rippers"
[sdl]
fullscreen=true
fulldouble=false
fullresolution=1920x1080
windowresolution=1024x768
output=overlay
autolock=true
sensitivity=100
waitonerror=true
usescancodes=true
priority=higher,normal
mapperfile=L:\Games\D-Fend Reloaded\mapper.map
[dosbox]
machine=svga_s3
captures=L:\Games\D-Fend Reloaded\Capture\Sierra41\
memsize=16
[render]
frameskip=0
aspect=true
scaler=normal3x
[cpu]
core=normal
cputype=auto
cycles=fixed 10000
cycleup=10
cycledown=20
[mixer]
nosound=false
rate=44100
blocksize=1024
prebuffer=10
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplrate=44100
oplemu=default
Show last 48 lines
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=1
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[dos]
xms=true
ems=true
umb=true
keyboardlayout=US
[joystick]
joysticktype=none
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[autoexec]
@echo off
SET PATH=Z:\
keyb US 437
mount C "L:\Games\D-FEND~1\VIRTUA~1\"
echo.
C:
cd\
cd \GAMES\SQ4
Z:\config.com -securemode > nul
SIERRA.EXE
exit
Reply 1 of 5, by NY00123
Just a couple of suggestions:
- Try changing the value of the DOSBox "output" setting to any of the other choices.
- NVidia's "Vertical sync" may have an effect. Truly, since NVidia's setting is configured to respect DOSBox' behaviors (which means to disable VSync when opengl/openglnb output is used), I don't think this should have an effect, but I'm still mentioning this, just in case.
Reply 2 of 5, by YaketyYakumo
I'm having the same issue, but it's not G-Sync related (I have an AMD card and two non-Freesync monitors). Seems to appear regardless of output options. Any ideas?
So far it's been an issue in Carmageddon and Wing Commander III - it'll be running just fine but as soon as I jiggle the mouse, stutter city.
EDIT: Rebooting fixed it, must have been something I had running in the background?
Reply 3 of 5, by bola1717
GSync is the culprit in my Case too. On second, non Gsync Monitor it´s flawless.
Reply 4 of 5, by DosFreak
I haven't specifically tested gsync with DOSBox but I do have a gsync monitor.
I thought by default gsync only applies to fullscreen?
Have you tried other DOSBox output options?
Make your games work offline
Reply 5 of 5, by hwh
Was having this issue.
I am using openglnb and don't want to change that since that drastically lowers quality.
MiniMax recommended
Try forcing the core=dynamic and set frameskip=1.
Now, unsure which of those two seemingly did it, or if that's what I will stay with, but the effect was immediate.
