First post, by Zorbid
😈 Hacktarux, the author of Mupen64, a N64 emu has started to write glide3x to OpenGL wrapper. He's got tons of stuff working in one single week of coding 😀:)
It's only been tested with GLide64 (the N64 plugin) this far...
He will probably stop working on it rather quickly, and open the source.
http://www.emuxhaven.net/forum/index.php?showtopic=4533&st=0
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
neat. Mupen64 is quite an accaptable n64 emulator for linux.
I use it myself 😀
Water flows down the stream
Reply 2 of 3, by Zorbid
The third beta is out.
It seems to be much better than eVoodoo, feature wise, dunno about speed. It has Multitexturing (you need a graphic card with at least 3 texture units), fog working, and almost no glitch...
Reply 3 of 3, by Targaff
Just to note that this has been updated again in the last few days; beta 5 can be found here.
