First post, by FFXIhealer
Ok, I need some help here because I've hit a wall after working half of the day today trying to figure it out. I'm trying to install Windows 95 brand-new onto a PC. The hardware is as follows:
Motherboard: Micronics m55hi+ Revision B
BIOS: PhoenixBIOS 4.06
CPU: Intel Pentium 200MHz
Hard Drive: Maxtor 32049h2 20.4GB installed on IDE-0 Master
CD-ROM: Installed on IDE-1 Master
Installed graphics card works because I can see the BIOS boot screens and DOS stuff, so we're not worrying about that yet. I can get drivers installed later.
I used the only spare 3.5" floppy I could find. Formatting it on a USB floppy drive from Windows 10 didn't let the computer read from the disk, so I used my Windows 98 machine to re-format. It found about 9K in bad sectors. After that, I copied all the files I downloaded for Windows 95a, which was 31 files total. http://www.allbootdisks.com/disk_contents/download/95.html
Testing a boot on this system the first time worked. I could see the contents of the Windows 95 CD-ROM using the letter R:, but I could not open C:. Entering FDISK showed 1 NON-DOS Partition for the 20.4GB. I deleted the partition and created a new Primary DOS partition. This created a 2GB partition. Exiting, I get the standard "you must restart your computer and then FORMAT to use it" message. So I restart the system and it begins to read from the floppy...but I never get to see "Starting Windows 95..." like I did before. It just stops.
So I took the HDD out and stuck it into my W98 PC as a slave and deleted the partition in FDISK. Sticking the blank disk back into the older PC and the Windows 95 disk boots properly again, but still FDISKing a partition onto the drive prevents the system from booting.
So I tried to erase and create a Windows 98 startup disk (I remember using a W98 floppy to install W95 before more than once) and IT ALSO FAILS TO BOOT from the HDD once a partition is there.
So I wiped the partition AGAIN and this time tried to use the FORMAT command immediately after exiting from FDISK, but "format c:" only gives me: "Invalid drive specification".
Trying to run the SETUP.EXE from the Windows 95 CD-ROM errors out with a "cannot create a temporary directory".
If this is a hardware-level problem, then I can see only two options so far: 1) use a 1GB SD card with an IDE adapter or 2) get a PCI IDE controller card that can use a drive larger than 8GB.
Any advice or procedures that I haven't tried would be welcome at this point. I've pretty much given up for the day. I'm still excited about the 600MHz Pentium III that went into my Windows 98 PC. Benchmarks have been posted, by the way: CPU upgrade w/Benchmarks
