First post, by cj_reha
I've got an ABIT BE6 board in my 98 computer and it has this weird error that pops up and is apparently unavoidable.
"CPU is unworkable and has been changed. Please recheck - CPU SOFT MENU"
I've replaced the battery and cleared the CMOS already multiple times. The error doesn't go away.
The Pentium III 600E/256/100 in it defaults to the lowest clock speed, 400E, when the computer is turned on. Whatever settings you save in the CPU SOFT MENU are cleared and reset back to the lowest setting again every time the PC is started up. It's not the CMOS chip, though, since it saves everything else, and the date and time are still correct.
A temporarily problem solver I've used right now is to make the BIOS bypass all errors, keeping the boot process uninterrupted, but changing the speed to 600 every time is pretty annoying. Any help would be greatly appreciated.
Reply 1 of 21, by Artex
Do the caps look good? ABit boards are notorious for failing capacitors.
Reply 2 of 21, by Jade Falcon
Rank BANNED
BANNED
Did you set the cpu setting in the bios right?
Also try flashing the newest bios on the board.
It could also be the caps, I believe that most BE6 boards used crummy caps, might not be stable at full speed so its down clocking the cpu to keep it stable, try setfsb after windows boots up to change the cpu speed and be sure to check the caps.
Reply 3 of 21, by PhilsComputerLab
Funny I just worked with that same board today 😀
- Check the CMOS battery with a volt meter
- Check the position of the CMOS clear jumper
Also what BIOS do you have? SS is the latest version I believe.
Reply 4 of 21, by Jade Falcon
Rank BANNED
BANNED
That was my first thought but he said everything else was saved. still worth a look.
Reply 5 of 21, by ODwilly
I second the capa, not sure what brand the BE6 uses but they are most likely bad. The Jacksons on the VP6 go bad without any physical sign in my experience.
Reply 6 of 21, by havli
I believe there is option in the Soft menu (don't remember the exact name) that can deactivate this annoying message. Also it might help to set CPU as manual (6x100 MHz), not the predefined 600 MHz preset.
Reply 7 of 21, by cj_reha
Necro'ing this thread, please forgive 😵
Out of the blue, it's defaulting to 600E now. Weird..I don't remember modding the board or anything.
Problem solved, I guess? Time to overclock 😁
Reply 8 of 21, by Ampera
Electrolytics are tricky. They probably got board of sitting in a closet and decided to work.
Also I wouldn't call 4 days necroposting.
Reply 9 of 21, by c0keb0ttle
I had the same problem with my old BH6 when I brought it out of retirement, on exactly the same CPU as you. I solved it by flashing the latest BIOS. I think. Or maybe it solved itself, like yours, and it was just a coincidence. Who knows, right? YOLO. 😁
Reply 10 of 21, by PhilsComputerLab
SS is the latest BIOS version I believe. Just in case, I've attached it.
How are you finding the board? I've been using for a benchmarking marathon, still got work ahead, and it's been fantastic.
Reply 11 of 21, by gdjacobs
Are the BH6 and BE6 really BIOS compatible?
Reply 13 of 21, by PhilsComputerLab
All this time my brain told me this thread is about the BH6. 😵
Reply 14 of 21, by Tetrium
Happy new year Phil! 😁
I somehow keep mixing up certain model numbers, even when already having been corrected by multiple persons 😵
My retro rigs (old topic)
Report spammers here!
Reply 15 of 21, by PhilsComputerLab
We're getting old 😒 😢 😵
Reply 16 of 21, by Tetrium
🤣. And oh well, as long as we're not getting too cranky along the way 😁
Reply 17 of 21, by cj_reha
Hmm, the problem is back. Can still OC to 688 (650 in BIOS) but it defaults every time again.
Will probably recap with Japanese caps sometime.
Reply 18 of 21, by kaputnik
Just to make sure, by "make the BIOS bypass all errors", you mean disabling the Speed Error Hold setting in the CPU soft menu, and not changing the Halt On setting? Had to do that to get my BH6 to accept a PIII 1.1GHz, it behaved just like your board before if I remember it right.
Also, could you post your CPU soft menu settings?
