First post, by fil_evans
fil_evans
Offline
hello all
does anyone know how to get the joystick working in this game, as I've tried all the different joystick types and timed on/off
when you go to calibrate the joystick it tells you to move the joystick to all positions then after press a button - but not even a button on the joystick will work
thank you all
