First post, by eax
I've assembled a 486 pc, the cpu is a A80486DX-50 which probably needs a heat sink as it gets hot (= too warm to touch) quite fast.
The plastic remains of a heat sink frame which attached the heat sink to the cpu are still there but broken beyond repair.
I do have sticky heat sink foil to glue them directly to the ceramic package but I think that will also dissolve the white markings of the cpu, which I'd like to preserve.
Is there a simple way to attach the heat sink without using glue?
Any replacement suggestions or maybe a source for new heat sinks (with fan maybe)?
