First post, by a_macintosh
- Newbie
I heard you can browse the internet on System 7.5.5 is this true? If yes then the Macintosh Plus computer could actually go on the internet 😐
You can "Browse the internet" on anything if you program it to do so. Even the Apple II could probably run a text based HTML engine if you an an external IP stack.
wrote:I heard you can browse the internet on System 7.5.5 is this true? If yes then the Macintosh Plus computer could actually go on the internet 😐
Get a Mac with system 7.5 and try it.
wrote:wrote:I heard you can browse the internet on System 7.5.5 is this true? If yes then the Macintosh Plus computer could actually go on the internet 😐
Why do you keep starting threads with the same question over and over again?
As for the question, get a Mac with system 7.5 and try it.
Unless I am missing something, it's not the same guy.
wrote:wrote:wrote:I heard you can browse the internet on System 7.5.5 is this true? If yes then the Macintosh Plus computer could actually go on the internet 😐
Oh, oops 😊 Sorry about that.
