I have one of these boards myself and it does the SAME thing. Using a 4-digit POST code testing card I get - - - - on the display, no matter what I do. No beeps, nothing. I can run the system with all the components or run it without anything else connected at all (just the board and PSU, no CPU) and it still does the same thing. I've tried multiple CPUs, multiple RAM sticks, everything. Since there are no beeps or any POST codes at all, I'm thinking it is failing very early in the process.
Does this sound like a BIOS problem?
If so, my best bet is probably to get a less desirable board that I have laying around and hot-swap the BIOS chips to program one for this board. Are all BIOS chips from this time period likely to be compatible with all sockets as long as they are physically the same size and number of pins?
EDIT: Apparently, this board just needed to hear the threat of having its BIOS hot swapped into another system. Strangely, after disconnecting the keyboard, putting in yet another stick of SDRAM and reinserting a CPU, it started giving beep codes! When I inserted some EDO RAM (it has SIMM and DIMM slots) it booted right up without a hitch! I'll have to check the BIOS settings to figure out why it doesn't seem to want to POST with SDRAM, but the BIOS seems to be fine.
I have no idea why it wouldn't come on before, but I'm happy its working. The board is absolutely pristine. It may not have ever even been used.
EDIT2: Woohoo! Apparently the crazy DRAM speed select jumpers (which are split between two different banks of jumpers) were set to run at the AGP Clock, rather than the CPU clock. Some of my SDRAM still didn't want to run in this board but the Samsung 128MB PC-100 CAS3 stick I've been using for testing booted up perfectly after switching the DRAM jumper to CPU Clock (100Mhz in this case). Still no idea why it was totally dead earlier, but I'll keep playing with it just in case the problem returns. This seems like a nice board though. FSB overclocking settings on the board, well documented jumper settings, nice BIOS options... it even has a "Y2K CMOS Update" enabled/disabled setting in the Chipset Features Setup. 🤣
