First post, by wayno
Another Newbie, downloaded Dosbox0.61-win32-installer
but can't open file.
ERROR Message: The NTVDM CPU has encountered an illegal
instruction. CS:Odae IP:0119 OP: 65 63 74 20 61
System Information
HPPAV 7920
Windows XP Home Edition (5.1, Build 2600) Service Pack 1
BIOS: Version 2.11
Processor: Intel Celeron, ~890MHz
Memory: 510MB RAM
DirectX Version: DirectX 9.0b (4.09.0000.0902)
Card name: NVIDIA GeForce4 MX 440
Display Memory: 64.0 MB
Monitor: hp pavilion mx50
Creative Sound Blaster PCI
NOTE: On first download it unzipped OK but there was no
dosbox.exe file so was unable to install and winxp was unable
to open any files, including the text files.. Deleted and
redown loaded and now can't open or unzip the file.
wayno
Reply 1 of 6, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Check the file you downloaded. Is it really the installer? Somebody reported here similar problems then finding out that in reality it was an HTML file .... The attempt to run it lead of course to crash.
After you run the file, installer starts. No need to unzip anything. It is EXE file.
Mirek
Reply 2 of 6, by samtam90
Have you downloaded the file from HERE?
Reply 3 of 6, by wayno
Yes, I did.
Reply 4 of 6, by dinka
I've got the same problem!!!How can I do???thanks to answer
Reply 5 of 6, by dinka
It work!!! I went to telecharger.01net.com/windows/Jeux/ patches/fiches/27476.html
sorry it's a french one!you download and after it work but now I can't do the " \ " on dos. How can I do?
Reply 6 of 6, by MiniMax
Rank Moderator
Moderator
Try using '/' instead of '\'-
_________________
