Licence to Kill - Dosbox
First post, by Chilly Willy
For some reason I can not get this game to run in Dosbox. I have the original 720k disk. One has EGA/Tandy and the other has CGA/Hercules. They work on my Tandy 1000 HX just fine. I have tried setting the machine as Tandy and even mounting the A: drive and running from there. The game never starts and just goes back to the prompt after trying to run them (BONDE.exe, BONDT.exe, BOND.exe). Any advice?
Reply 1 of 4, by firage
Probably protection on the disk?
My big-red-switch 486
Reply 3 of 4, by Chilly Willy
Sorry for posting in wrong forum. 🙁
I don't think it has any protection on disk. Runs on my Tandy without having to do anything. I don't recall it saying anything like that in the manual either.
Reply 4 of 4, by Jorpho
Back in the day there were various sorts of complex copy protection schemes that would not require you to do anything. Robot Odyssey, for instance, had a "weak bit" that would not be duplicated correctly if you tried to make a copy of the disk.
As the floppy emulation in DOSBox is limited, it is entirely possible that some such copy protection scheme is in play.
