Is DOSBox Daum dead?
First post, by Phobos Anomaly
Last update was Jan 25 2015. Has Taewoong stopped working on it completely? 🙁
Reply 1 of 37, by lightmaster
Yup.
Reply 2 of 37, by Phobos Anomaly
What can I replace it with? 0.74 is too old and lacks features only Daum has.
Reply 4 of 37, by gdjacobs
If you like, you can start with SVN and begin pulling in patches.
Reply 5 of 37, by Jorpho
What features are you looking for?
Reply 6 of 37, by Phobos Anomaly
Working Direct3D support for a start.
More scalers.
Vmemsize options.
Support for Fluidsynth.
Reply 7 of 37, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You can find the patches for those and build DOSBox with these patches on your own. It's not THAT difficult, you will learn a lot and you are free from the whim's of someone else who might no longer cater your needs.
But why don't you just continue using an old Daum built (just don't use the last one, that one was broken in places)?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 8 of 37, by gdjacobs
I don't get the point of having synthesizers built internally (except on phones due to platform limitations). Running Munt or Fluidsynth as a MIDI service on your computer is not hard.
Reply 9 of 37, by Phobos Anomaly
Is the second latest good then?
Reply 11 of 37, by Asterisk
There's one major benefit: with the synth integrated into DOSBox, the MT-32 or GM music is included in the audio stream of captured video, which is a lot more convenient than dumping the audio stream to a separate wave file via external tools and then manually muxing it back together with the video, hoping that you've got it synced properly.
Reply 12 of 37, by gdjacobs
Fair enough. Someone needs to come up with a DOSBox "clap board" for you video streamers!
Reply 13 of 37, by Azarien
Is the source code of Daum version available?
Reply 15 of 37, by Darklord42
Technically speaking, fluidsynth doesn't need to be built into dosbox itself to work. On my linux system, it is my goto softsynth, and I just tell dosbox to route midi to the appropriate alsa port.
Reply 16 of 37, by gdjacobs
Yes. This has already been discussed in the thread.
Reply 17 of 37, by AJN
DOSBox-X looks good to me. OpenGL seems to be broken in the latest official binary build (which is almost two years old), but they are still working on it. You can try to compile it yourself:
https://github.com/joncampbell123/dosbox-x
There's an updated binary where OpenGL is fixed (don't know if this is included in the latest official source):
DOSBox-X branch
Works for me, I can set custom window resolutions now, but they only work in OpenGL (OpenGL_HQ is still broken).
Reply 18 of 37, by leileilol
I don't think any fork with a removed dynamic recompiler looks good.
long live PCem
Reply 19 of 37, by awgamer
Where's the go to place for the list of patches? daum has a lot I've never heard or seen, no idea where they were sourced.
