Gateway 2000 P5-120
First post, by Old Man Newbie
Hello Everyone
I just came into possession of a gateway 2000 tower
It has a pentium 120 and 32megs of ram.
the
motherboard Id is AA 652605-501 with a 430fx chipset Chip number SB82437FX66
Does anyone know where I can get motherboard info- Jumper settings of download chipset drivers?
I would like to install Windows 98SE as the machine is in pretty good shape.
I have a Pentium 166 but don`t know if voltage has to be changed on the board
Thank for your help or any info or opinions
I7AZZ3V.jpg?1
TZgFA4f.jpg?1
Y47wUTg.jpg?1
Reply 1 of 10, by jheronimus
Hi! Chipset drivers shouldn't be vendor-specific, just get the newest ones that support your chipset here.
As long as that Pentium 166 is Classic and not MMX, you should be fine with voltage. However, you need to change bus clock and clock multiplier: Pentium 120 = 60 MHz x 2, Pentium 166 = 66 MHz x 2.5. Jumper settings for that should be silkscreened on the motherboard itself.
MR BIOS catalog
Unicore catalog
Reply 2 of 10, by yawetaG
Old Man Newbie wrote:
Hello Everyone I just came into possession of a gateway 2000 tower It has a pentium 120 and 32megs of ram. the motherboard Id […]
Hello Everyone
the
You might want to use Google to search the Gateway site for information on your specific model number ("P5-120"). They still have a lot of manuals, drivers and data sheets available, but those can't all be accessed via the Gateway homepage itself.
Is it this one: https://panam.gateway.com/s//MOTHERBD/SOLECTR … 2500420nv.shtml?
Reply 3 of 10, by Old Man Newbie
Thanks for the info. I go to phils site quite a lot. none of those drivers will install on win98. Windows 98SE installed and works but shows the only a standard hard disk controller with no DMA.
I may have to go to windows 95
Reply 4 of 10, by Old Man Newbie
Hello Everyone
the
Thanks for the info. that one is similar but has the VX Chipset still at least it shows some jumper settings that look close to my board
Reply 5 of 10, by Windows9566
The Advanced/ATX (Thor) AA652605-501 board supports the Pentium 75 all the way to a Pentium 166
Jumper Settings
https://stason.org/TULARC/pc/motherboards/I/I … VANCED-ATX.html
R5 7600X, 32 GB RAM, RTX 3060 TI, Win11
P3 750, 384 MB RAM, Matrox G400, Sound Blaster 32, Win98
PMMX 166, 64 MB RAM, S3 Virge DX, Aztech AZT2316R, Win95
486DX2 66, 32 MB RAM, Cirrus Logic GD5430, Aztech AZT2316, DOS
Reply 6 of 10, by oeuvre
beautiful rig!
Reply 7 of 10, by SpectriaForce
I like the originality and condition of this pc! #jealous 😊
Reply 8 of 10, by Windows9566
i found that same Intel AA652605-501 motherboard with a Mr. BIOS instead of the 1.00.0X.CN0T AMI BIOS
Reply 9 of 10, by dkarguth
hey, I have a gateway that looks almost identical to that! Mine's a G6-200, though. Came with a pentium pro and around 128 megs of ram.
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 10 of 10, by amadeus777999
Looking mightily fine and clean.
