I7 950 to W3670
First post, by candle_86
So I'm planning to make this swap on a newly acquired computer, question however is do I have to buy ECC Ram like some of the quad core 1366 Xeons or will regular ram work with it, this is my new main rig, my i7 was traded for a master brake cylinder for my Nissian Xterra as the one in it cracked and its the only transportation we have so it was kinda necessary
Reply 2 of 7, by candle_86
Kamerat wrote:
Regular RAM should work, never heard of a 1366 Xeon that requires ECC.
I have had a few of them in PRecision T3500's that required ECC, we ended up scrapping them at work because we didn't have any extra ECC ram to boost them above 4gb of ram, they where Dual Cores with hyperthreading 1366 Xeons
Reply 3 of 7, by Jade Falcon
Rank BANNED
BANNED
I could be wrong, but I have used a lot of 1366 xeons in the past and I don't think any retail 1366 xeons have to use ecc ram. its governed my the mobo chipset/bios, the cpu's can use ether ecc or non ecc ram. but some motherboards can't use non ecc ram.
Reply 4 of 7, by candle_86
Well on one of them we put in a Core i7 from a blown T3500 just to test, and suddenly it didn't require ECC 🤣
Reply 5 of 7, by Jade Falcon
Rank BANNED
BANNED
what cpu did they have? Maybe the motherboard bios required ecc ram when ever a xeon was in it
I used a lot of 1366 Xeons in the past and this is the first I hard of the ecc requirement.
Reply 6 of 7, by havli
Same here - all my Nehalem-based Xeons (either E55x or W35xx) works just fine using regular DDR3 and Gigabyte X58 board. Westmere should be no different.
Reply 7 of 7, by nforce4max
Won't hurt to just give it a try and later generations work just fine with standard ram including lga 2011 xeons.
