First post, by jheronimus
Hi, all
I have an AMD 5x86/VLB system. Here are the specs:
AMD 5x86
16MB RAM
Chaintech 486SLP/4SLD3 motherboard
ASKA SST-2946 VLB multi I/O
1.6GB Samsung HDD
It runs MS DOS 6.22. The HDD is connected as primary master IDE device, the CD drive is connected as secondary master. I've used Phil's MS-DOS starter pack to install the CD driver. However, this is what I get on DOS boot:
(all images are clickable)
This is how the BIOS device table looks. I've ran BIOS drive autodetection routine, but I'm not sure how the drive should be configured, since the BIOS only has options for various HDD geometry.
I've tried two different drives:
- a 4x Creative;
- a 12x Pioneer — I used this one on other builds.
In both cases the drives spin up on boot and after the DOS is finished loading and gives the abovementioned error message.
What am I missing? Thanks!
MR BIOS catalog
Unicore catalog
Reply 1 of 7, by Nipedley
What are your jumper settings on the drives? Are you using them on two seperate IDE channels and seperate cables, where they woudl both be set as Master? If on the same channel/cable then one will need to be set as Slave. I've also found cable select to not play nice with my VLB 486
On my 486 you don't need to specify any drive at all in BIOS, I just have my D set as None, only HDD is specified. For the record, I have my primary IDE channel with HDD set as Master on a single cable, and secondary IDE channel with CD drive set as Master on a single cable
Have you tried booting from a Win98 startup floppy and checking CD access to rule out the driver from Phil's pack?
Reply 2 of 7, by Ampera
This is an easy fix.
Remove any previous driver installation you might have for CD drives.
Make sure your drive is connected to the first channel (First port on the M/I/O card, can be master or slave), and set it to Cable Select.
Now install the CD1.SYS driver as you would normally.
Profit.
Reply 3 of 7, by jheronimus
HDD — primary master.
CD — secondary master.
So they're both on separate channels and explicitly set to master.
My CD is set to "none" right now (you can see the last BIOS screenshot in the original post).
Nope, will try that.
MR BIOS catalog
Unicore catalog
Reply 4 of 7, by jheronimus
Ampera wrote:
This is an easy fix. […]
Profit.
Right now they are set as:
But if I understand you correctly the issue is that they need to be:
CD — primary slave?
MR BIOS catalog
Unicore catalog
Reply 5 of 7, by kixs
I'd try it as a slave drive (like Ampera suggested). Set jumpers accordingly.
Reply 6 of 7, by Ampera
You need to set the other drive as Cable Select. Otherwise it will not work. It's weird, I know, but my DTC EIDE controller demands that.
And yes, the CD drive needs to be on Primary Slave, with the boot drive on Primary Master, but as I said, do NOT set the CD to slave. It needs to be set to Cable Select even if your using a 40 pin cable.
Reply 7 of 7, by kixs
I'd say it's more of a drive dependent feature. But you never know till you try 😉
@jheronimus:
About IDE 2nd channel... some BIOS's have an option do enable it. Check your BIOS.
