Hello, I have this (probably) OEM TNT2 Pro. At least, according code on internet, should be TnT2 Pro.
Can someone identify, what OEM brand it was used in (maybe Compaq computers? )
Is the card exactly same fast at same speed as TNT2 or TNT2 Ultra? I mean when I set core and memory speed at same speed? I want to use one card for benchmark all 3 versions of TNT2 (TNT2, TNT2 Pro, TNT2 Ultra) but they are too expensive to have all 3 of them, so I was thinking about getting cheap OEM TNT2 Pro, and in benchmarks, set speed to TNT2 and TNT2 Ultra speed, to get same result and use it as benchmark result. Not sure if it differ somehow on same clocks as core had been obviously shrunk and maybe had also revision changes?
Also, any comments about this version of TNT2 Pro? Is it same good as non-OEM? Anyone has same card and experiences? Will it handle overclock of Ultra speeds? (so 183 Mhz memory clock)
