First post, by judithdixon
Hello Forum Members,
I realize that the primary use of Dosbox is for running DOS games but I have been using it for the past several years to run a braille display. I have been running it on three different computers, all running Windows 7. I made the necessary changes in the [serial] section so that the DOS software that must run under command.com could talk to the braille display:
serial2=directserial realport:COM2
I also made changes in the [cpu] section and set cycles=fixed 35000. This number has varied somewhat from machine to machine. Once at a DOS prompt, I can then run WordPerfect for DOS, the WordPerfect shell, dBase II Plus, and DOS braille translation software and have perfect braille access.
I recently got a new laptop, a Lenovo x260 with a solid state hard drive. I have made the same changes to this installation of Dosbox but things are not going well. I have tried all kinds of cycle values including "max" but problems persist.
Here are the symptoms: Navagation buttons on the braille display: go to top, go to bottom, go to cursor are not taking me to the right places. At "c:\>" when I type "dir" for example, as I type "d" nothing changes, then when I type "i" I can see the "d" on the display and when I type "r", I can see "di." But if I hit enter at this point, the directory appears.
I have no idea what is visually on the screen but if that would help, I can take the laptop to work and ask one of my colleagues.
I did try vDos but because of the graphical interface, it is completely inaccessible to a Windows screen reader.
Does anyone have any suggestion of what I might try to get this working? Thanks much.
Best,
Judy
