First post, by jarreboum
Ok so first off I know nothing about server racks and their standard.
I have this case which, though a desktop not a rack, seems to conform in terms of slot placements to a 2U server case.
(The white one is mine, the black one is a random server)
I bought a 2U riser card to go with it, the only one I could find that would rise an ISA card, the GHP-200 from Guanghsing Industrial Co.,Ltd.
But it doesn't fit! More specifically, it's too short: when populated with cards, the riser hovers just above the PCI slot it should fit in, less than a millimetre above. If I fit it properly, it places the cards exactly halfway in between the case cut-outs. As if the middle card top cut should align with the backplate top cut.
The case optionally comes with a 3xPCI riser, which I suppose is standard sized:
I don't understand why a 2U riser doesn't fit in a 2U case. And to make matter worse, it's the only riser I could ever find with an ISA slot.
I do have a radical solution: cutting away the topmost PCI slot so that I can fit a flexible PCI riser in its place. The ISA part is connected via the ribbon so would be unaffected. But it's quite a permanent solution and I would like to avoid resorting to such a drastic measure. But I don't see any other way.
