The Quad-SLI Qunundrum
First post, by ProetusXtal
Here is the long story:
I walk into my parents house and am chatting with them a little bit, I started reminiscing about my brother's old Alienware computer that my dad had gotten free from his work. He works at a more upscale movie theater in Ann Arbor, MI and they had this gaming area in the theater for a few years, I believe it was called CyGamez. Anyways, when they shut it down after a few years my dad brought home one of the many PCs they had there for my brother. I think the model was Aurora 7500. Anyways, I asked my bro if he had any of the components leftover from it, my dad then chimed in and told me that they gave him almost all the graphics cards from the computers. He said he had sold most of them but he had a few left. What was leftover were 3 Geforce 7950 GX2s. I was psyched, the first quad-SLI! I was instantly hooked on this idea.
So here we are, I decide to build my girlfriend the most awesome 2007 build based on these cards. Then the problems begin...
Here is the setup I ended up with:
EVGA 750i SLI FTW Motherboard
Intel Core 2 Q9400
Geforce 7950 GX2 x2
Refurbed WD 320GB - Later changed to Brand New Seagate 500GB
Crucial Ballistix 2x2GB - Later changed to Atech 2x2GB
Seasonic 550W PSU - Later changed to EVGA 430W
HP DVD Drive
I got the mobo, ram, and cpu for $50 on ebay and had the rest of the stuff from other builds.
I got everything together and started the build, everything was going fine. All my parts were compatible, I got the bios flashed to the newest, replaced the coin battery, cleaned the board and all dust. Everything was looking really nice, I setup my bios and started the windows 7 install and I kept freezing up at random points during the install. Temps were showing very stable and good in bios, I believe mobo was around 25C most times. I tried the obvious tricks, only one stick of ram, unplugged dvd drive, reset cmos.
Then this is where I started replacing crap one by one. I replaced the ram, hard drive, and psu to no avail. I finally did some more digging and realized that the the northbridge chipset cooler did not have the fan that I see on it in most pictures. By this point I had realized that the computer would stay on without freezing for about 20 minutes, in which time I had installed Windows 7, Speccy, and HWmonitor. Both Speccy and HWmonitor were showing the mobo at 89C right when the computer booted, which seems unreal. I checked the bios and it is still showing around 25C. Nothing makes sense, I don't know why it would be freezing at 25C. GPU temps are between 50 and 60C with only one of the GX2s in.
So at this point, I decide to grab a 50mm fan from ebay for that northbridge chipset, although I read it should be stable without a fan, but the heatsink was definitely hot. I got the fan and I thought everything was good, Speccy and HWmonitor were still showing 89C for the mobo upon startup. The PC was able to last about an hour before freezing this time though.
I'm at the point of frustration now, I have no idea what to do. Should I replace the chipset coolers? Are the GPUs wasted?
If anybody has any insight or experience I would love to hear it, Sorry for the long story.
SHORT STORY:
My mobo is overheating or giving me inaccurate temps. The PC freezes after about 30 minutes until I installed a fan on the northbridge heatsink, then it lasted an hour and a half. I'm wondering if my GPU or mobo is the culprit, check the specs above if you don't feel like reading.
Reply 1 of 26, by ProetusXtal
And yes, I do realize it is spelled conundrum.
Reply 2 of 26, by deleted_Rc
Try the following:
- check manual for power connection (overeheating could by feeding to much power over a single 4 pin power connector, newer mobos have a 4 and 8 pin connector next regular atx connector).
- Check the mobo on the back for bad/ damaged lines.
- get the heatsink off and apply new thermal paste (proper thermal paste can make 5 degrees difference), is the fan powerful enough (high enough CFM)
- how is the air flow in your case (positive, neutral or negative static pressure? Ie how many intake compared to outake fans).
Consider aftermarket cooling (zalman usually offers great packages against decent prices)
Also I suggest considering water cooling.
Before you say anything, I have been reading too much over clocking articles lately for my own computer 🤣
- I suspect your PSU is the culprit and maybe wrong power distribution to your mobo , check your VRM temperatures, better yet if possible send me a CPUZ and GPUZ result file and I can analyse it for you (my recent adventure with my new setup got me back up to date 😀 )
Edit:
You need serious cooling for this setup.
Cpu: 95 W Thermal Design Power
7950 gx2: 110 W EACH Thermal Design Power
Minimal power requirement for a single 7950 is 400W. I advice getting at least 800-1000W for quad.
Also notify your girlfriend to disable the heating. 🤣
Reply 3 of 26, by Ampera
While Richo is right on most other fronts, 550w is NOWHERE near enough for a 4-way SLI. Even still, higher wattage PSU is always safer. You'd probably be looking at 900-1000w reasonably.
There is a reason why NOBODY used quad SLI unless their pockets were the size of their computer case. It need a lot of power, kicks out a metric shit ton of heat, and NEVER means 4x the power.
And go right ahead and replace all the thermal compound on all the motherboard components. I suggest Arctic Silver 5 either using the pea method, or the apply and wipe off method (Which has actually worked in my family for years upon years, and it's worked well.) that means you apply it to the CPU, and taking a paper towel you just very simply wipe it across the CPU and get it in there. Don't remove all of it, but just have it so it fills in all the dips and cracks in the die/heatspreader. Do the same for the CPU/NB cooler.
And if something isn't getting enough airflow, put a good fan onto it. Not a small one, put a proper 80-140mm fan somewhere directly blowing on it.
EDIT: Totally forgot to add something. I mean to say while Richo is right on almost everything, you don't need watercooling unless you're going to OC a modern CPU. A regular heat pipe style air cooler will work just fine for the average system.
Reply 4 of 26, by ProetusXtal
Thanks for the replies! I think I will just forget about going quad for now and just think of it as a dream that could have been. I'm considering getting an 8800 GTS and calling it a day since it is more powerful than the Quad they say. I will follow all of these suggestions and get back to you guys, thanks again.
Reply 5 of 26, by deleted_Rc
For a old system like that it's for shits and giggles (same with going oldie V2 sli rather then v3). The only edfe the quad sli ensures is max fps possible for that time, a 8800 won't beat that.
Besides if you disable the heater during winter it might save you alot of gas on heating 🤣
I prefer a line of coke method for maximum spread over all corners. Artic silver is what I use currently, great stuff. My 5930 runs at 25°c idle and under °40 during torture(water cooled) (4,4 GHZ oc it runs under 50°c, with 4x 120 mm and 2x 140mm), VRM stays surprisingly cool around 60°c.
Also water cooling is still a option , cheapest 775 set just in for €50 new (designed for 140 TDP, thus ensures a 30 degrees cp at max load I reckon), this saves alot in cooling inside the case.
My advice don't give up so soon, there is plenty of people who can help you here and like to see this project happen.
Reply 6 of 26, by sprcorreia
Did you ever had a quad SLI with 7950GX2?
Reply 7 of 26, by Ampera
No, no I haven't, but I have enough computing experience to know that any 4x SLI capable card isn't going to take a few watts of power.
And Richo said the TDP was 110W.
Reply 8 of 26, by sprcorreia
Clearly not enough experience...
To OP, I ran a 7950GX2 quad system, M2N32-SLI Deluxe with a Phenom X4 cpu (more power) with a 600W PSU. Never had a problem.
Reply 9 of 26, by agent_x007
Make sure RAM is stable and IMC in North Bridge is cooled (demount NB cooler and check paste underneath, I'm positive it's hard rock mess since NV chipsets for LGA 775 are REALLY hot).
Use memtest86+ from pendrive to check RAM.
Also, seeing S.M.A.R.T. status from HDD may be helpful...
Reply 10 of 26, by FFXIhealer
Also be aware if the MB is around 10 years old, it might be time to check the capacitors. Bad caps can cause all sorts of problems that are damned near impossible to narrow down: hard drives resetting, RAM sticks working then not working, certain expansion cards won't POST, CPU randomly locks up (Windows XP freezes), things like that.
Definitely want to reseat the heatsink on the Northbridge chip with brand-new thermal compound (TIM = Thermal Interface Material). I just today got my Abit KX7-333 motherboard back from being re-capped and it's made a world of difference for that 15-year-old MB. I'm waiting on a new copper-base CPU cooler tomorrow before I power the thing back on.
Reply 11 of 26, by Ampera
Richo said the TDP of the card was 110W. If that's the case then you need 440W total with four cards. That warrants more than even a 600W CPU because you're leaving around 160W for the rest of your system, unless Richo was incorrect. If that is the case, maybe you can inform us properly of the TDP of those cards?
Also, instead of insulting my intelligence, maybe you can just explain your experiences? I'm just trying to help, and no, most people on VOGONS have never used 4 way SLI with 2007 cards. This doesn't mean I can't apply some of my general computing knowledge to the issue. If the OP wanted to limit themselves to first hand experience, I suggest the Linus Tech Tips forum as they have more people that have that setup, because you will probably find few people here.
Reply 12 of 26, by FFXIhealer
Yeah, the only SLI I ever ran was 2x GTX 480. Man, that was a beast of a system...until one of the two cards began to die. Damned EVGA and their stupid designed-to-fail-after-2-years cards...
Reply 13 of 26, by deleted_Rc
you made me curious sprorreia, I looked up the TDP for cooling reference however considering atleast 30% of energy used is converted into heat (30% is positively speaking btw, I reckon that goes up to an easy 40-50 if not more btw). Could explain how a Quad SLI would be able to run on your setup while a single card system is adviced to have atleast 400W of power (yes I do realise other components use power aswell, although this was calculated pre emptively by Nvidia).
Me I have never used Quad SLI before for the simple reason: WHY? I aint spending €5000,- while a €700 card will do just fine aswell. Most I did was run 7800 GTX SLI because I go the card VERY cheap of a friend who upgraded to a 8800.
ampera wrote:
Richo said the TDP of the card was 110W. If that's the case then you need 440W per card. That warrants more than even a 600W CPU because you're leaving around 160W for the rest of your system, unless Richo was incorrect. If that is the case, maybe you can inform us properly of the TDP of those cards?
I reckon this is while being tortured for again cooling reference, but its also an indication to how much power the card would use.
OH and I am never wrong 🤣
CLICKY
likely cooling problems, EVGA does OC the cards with poor cooling from my experience against high prices (The reason I stay away from those stock OEM OC cards)
Reply 14 of 26, by FFXIhealer
I got an identical card from Galaxy, a GTX 480 reference with a blower. And I never did get the overclocked versions. It's just that my first EVGA 480 went dead as the primary card in my SLI setup by crashing Windows and throwing artifacts over time. Mainly it was the crashing Windows thing that pissed me off. So I removed it and elevated the Galaxy card up to the primary PCI-Express slot. I called EVGA and even though I was out of warranty, they replaced the card with a refurbished unit out of their warehouse. So I ran SLI like that for another year before...AGAIN, the EVGA card began to not work properly. Had to remove it again.
But I'm still rocking the Galaxy card just fine in my older system. I wonder if it's a capacitor problem or if I can bake the EVGA card to get it working properly again. I mean, nobody sells 480s anymore. Besides, I'm keeping my eye out for another MSI 980ti blower to come down in price so I can SLI my current setup.
Reply 15 of 26, by agent_x007
You can't use 4x 7950 GX2's for Quad SLI (not enough SLI fingers). Maximum ammount is two (but since GX2's have two GPU's per card, we get Quad SLI with two cards).
Reply 16 of 26, by sprcorreia
7950GX2 already is an SLI card (2 chips, 2 x VRAM), so for quad you need two cards.
So instead of talking of what you clearly don't know maybe you could go read some stuff to at least be more informed when trying to pass good advices to others based on your "experience".
Except this time? Clearly you don't know what a 7950GX2 is...
And is clear that the OP is talking about 2 cards, it is right there in the first post. The x2 part? That's right, two cards.
Reply 17 of 26, by deleted_Rc
sprcorreia wrote:
7950GX2 already is an SLI card (2 chips, 2 x VRAM), so for quad you need two cards. […]
Tone it down abit will ya, we are all here to learn and help eshoulder. No one has all the knowledge and I jumped in on the cooling part of the build from OP(as believe is an important part of his problem). As I mentioned in my earlier posts and by OP it is likely his system is overheating and his vrm plays a part in it or something g that's overheating ether due cooling or poor distribution (bad caps maybe). Furthermore I replied with TDP for reference as 310 TDP is alot of heat without proper cooling.
So if you please contribute as am I am also interested in this topic, until now the only thing you achieved is bashing other members for no valid reason.
Next time when editing quotes from others, please post the full quote for the right context. It's annoying how you use the quote wrong.
Reply 18 of 26, by sprcorreia
Richo wrote:
Tone it down abit will ya, we are all here to learn and help eshoulder. No has all the knowledge and I jumped in on merely on the cooling part of the build from OP(as believe is an important part of his problem). So if you please contribute as am I am also interested in this topic, until now the only thing you achieved is bashing other members for no valid reason
So... You don't know have a clue to what kind of card he has and still you gave the OP some advice to go and buy a 800-1000W PSU?
OK...
Reply 19 of 26, by ProetusXtal
Here's a little update, I attempted to follow all the aforementioned advice. I just put in an order for some thermal paste for everything.
Here is the teardown I just did:
You can see how I had attached that fan, pretty sketchy.
Here is one of the GX2s
The thermal paste was definitely not in great condition, it just kind of fell of there for the most part.
I'm not sure what this is on the Mosfets, not thermal paste, just some kind of rubber.
These have definitely gotten very hot, it's hard to tell in the pictures but the aluminum heatsinks actually have some burn damage on them. I'm wondering if there is damage beyond repair.
Here is the back of the motherboard, it looks good there is no visible damage. I used my analog multimeter to check some of the caps, most are giving good readings but I have a cluster of them giving bad readings. Let me know what you guys think, should I continue with this board.
I'm bidding on a 2007 750w PSU right now. Hopefully I can grab that. The Quad-SLI dream of the 2000s lives on!
