First post, by melbar
- Oldbie
I have tested these two pentium 4 cpu's today:
- - P4 2.66Ghz/512/133, SL6PE (core stepping D1)
- P4 3.20Ghz/512/200, SL6WG (core stepping D1)
Test setting was the same for both, i only want to boot without Hdd and check the BIOS data.
(Asus P4P800deluxe, Stock cooler (without thermal paste... only for test a few seconds).
Temperature directly after start @stock settings:
- - P4 2.66Ghz/512/133, @2.66Ghz/133FSB: 45.5°C / 113.9°F
- P4 3.20Ghz/512/200, @3.2Ghz/200FSB: 54.5°C to 55.5°C / 130.1°F to 131.9°F
Temperature directly after reboot and lowest clock settings:
- - P4 2.66Ghz/512/133, @2.0Ghz/100FSB: 40°C to 41°C / 104°F to 105.8°F
- P4 3.20Ghz/512/200, @1.6Ghz/100FSB: 52.5 to 53.5°C / 126.5°F to 128.3°F
Is this reasonable for two identical cores = Northwood?? Both have 55 million transistors and 131mm² Die size.
There is a delta over 10 degree's for the same architecture.
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
