q3 this slow?
First post, by mrau
hello,
so i just accindetally stumbled upon this https://www.youtube.com/watch?v=RJmVOiP0tCM
and now i see the hardware specs too, which are actually rather good compared to my first q3 experince; i was using a k6-2 350 with 64mb and a riva 128; the machine of this guy is imo faster than what i used: p200 has more fpu power than a k6-2 (and 3dnow usually only gives a few more fps at most), he has more ram and the voodoo also usually gave more fps than the riva - could anyone point out what im missing here? to my knowledge he should be playing this game at over 20 fps at least on this map;
also: anyone ever tested if the opensource versions of q3 are faster on retro machines?
Reply 1 of 10, by F2bnp
Hi there mrau.
Your old system was actually faster than this! Do keep in mind that this is a Pentium Classic 200, not an MMX, so your K6-2 350 should have been faster, especially if you were using the 100MHz FSB. He may have slightly more RAM than you did, although 64MB vs 80MB should for all intents and purposes be nearly identical, however if you were using 100MHz RAM it would have been faster than 66MHz EDO. On top of all this, the Riva 128 should actually be faster than the Voodoo 1, not by a whole lot mind you. Plus, we don't know what settings he used.
I'm pretty sure Quake 3 has some special detection for 3Dfx Voodoo 1 and 2 cards, but I can't seem to remember what that does. If anybody remembers, perhaps they could pitch in.
When you refer to opensource versions, do you mean sourceports? If so, I don't think they will be faster, in fact I'm pretty sure they will be quite a bit slower 😁.
Reply 2 of 10, by mrau
indeed, i did not think of fsb and ram clock :> although amd cpu were pretty bad at this 😀
to my knowledge voodoo did some small part of the geometry setup that most other cards did not, therefore a speedup was almost guaranteed; ill admit i dont remember what part of geometry riva could do but i would really like to see if a geometry accelerating unit as in geforce or that first card that ever came out could make this fluent;
back in the day i used an addon called maxfps sometimes that gave some 30-50% in quake, of course things looked ugly as the guy in the mirror 😁
Reply 3 of 10, by Zup
AFAIK, the source released by ID uses different (slower) libraries for sound and ports may be slower. Also, modern ports may use modern libraries (DirectX, OpenGL) that may not be available on your CPU/OS/VGA or perform slower.
I'm selling some stuff!
Reply 4 of 10, by havli
I did some testing few years ago and it seems the Pentium P54 and Voodoo 1 are both too slow for Q3A.
Q3A medium details 640x480:
P200 (3x66) + V1 = 12.3 fps
P200 (2x100) + V1 = 14.6 fps
P200 (2x100) + V2 = 17.5 fps
PPro 200 + V1 = 18.4 fps
PPro 200 + V2 = 24.9 fps
K6-2 300 (2x100) + V1 = 19.6 fps
K6-2 300 (2x100) + V2 = 29.7 fps
PII 300 (3x100) + V1 = 20.2 fps
PII 300 (3x100) + V2 = 37.9 fps
PII 450 + V2 = 42 fps
PII 450 + V3 3000 = 47.7 fps
Reply 5 of 10, by leileilol
That looks like r_picmip 0 which will absolutely choke a Voodoo1 (and a Voodoo2 in some spots) so yes.
Also the source ports out there aren't faster, hell they regress entire platforms for darned reasons.... Maybe except for mine 😜
F2bnp wrote:
I'm pretty sure Quake 3 has some special detection for 3Dfx Voodoo 1 and 2 cards, but I can't seem to remember what that does. If anybody remembers, perhaps they could pitch in..
Its detection is to limit the selectable resolutions, use their gamma GL extension and prevent trilinear filtering on Voodoo2 due to some multitexturing driver bugs
long live PCem
Reply 6 of 10, by F2bnp
Yes, the Voodoo 1 is just way too slow. I just remembered this great video from swaaye, using a Tualatin at 1050MHz:
https://www.youtube.com/watch?v=mXpoRJjsr-g
Nothing of real interest then. 😁 Do you have any photo examples of trilinear filtering on the Voodoo2? I seem to remember other games warning against using it (Blood 2 + Shogo) as well.
Reply 7 of 10, by mr_bigmouth_502
I remember ioquake 3 having terrible performance on the library computers at my old high school. 😜 I believe most of those boxes were Pentium 4 2.8GHz Northwoods with Geforce FX 5200s. They ran the normal Q3 client just fine, as well as Medal of Honor: Allied Assault, another Q3 engine game.
Reply 8 of 10, by leileilol
Yeah, though this is shown through r_colorMipLevels and a MesaFX ICD (to get around q3's v2 trilinear check, as well as vertex lighting so trilinear can actually work)
The attachment v2-trilinear.png is no longer available
It can also dither mipmaps together. This following screenshot is taken on a V3, same technique used (I couldn't get it working on my v2 driver for some reason)
The attachment v3-ditheredmipmaps.png is no longer available
long live PCem
Reply 9 of 10, by F2bnp
Damn, thanks for illustrating this. Is this an issue with every game that uses multitexturing on the V2? Can it do trilinear on older, non multitextured titles properly?
Also, what's causing this, hardware or driver issue and if the latter, why didn't 3Dfx ever fix it?
Reply 10 of 10, by leileilol
This is the latest of the latest official 3dfx drivers......so nope. Voodoo3's 3dfx tools help file mentions the multitexture limitation on trilinear as well
EDIT: Okay here's some VOODOO2 quake3 1.11 demo screenshots with MesaFX playing with some filtering settings. something available to the public to reproduce at least 😜
Dithered mipmaps are enabled through the V2 control panel in the Advanced>Glide section and doesn't seemt o matter whether you use trilinear or bilinear settings in a game
Turning it off allows true trilinear, but only on non-multitextured surfaces (i.e. vertex lighting)
long live PCem
