First post, by cj_reha
I recently purchased this Sound blaster vibra16 sound card at a local flea market for $2. It is recognized in Windows 98s plug and play and drivers are installed but no sounds come out of it. It looks like it has a lot of missing components, does it?
Thanks
Reply 1 of 6, by Jepael
They are missing, but not removed. It's a model without amplified speaker output, it has only line level output.
Reply 3 of 6, by gdjacobs
Have you tried the reference drivers from Creative on a DOS bootup?
Reply 4 of 6, by cj_reha
I believe the reason it doesn't work is the lack of an amplifier on it and me using some "Sound Blaster SBS30" passive speakers. 🤣 I'll find some powered ones and try it again.
Reply 5 of 6, by gdjacobs
Yes, that's logical. Passives will have output, but it will be extremely faint.
Reply 6 of 6, by RacoonRider
Or you could try plugging headphones in just to test if that's the actual problem 😉
