Strike Commander
First post, by GuyIncognito
HAHA! I found Strike Commander, I had the game years ago and lost it I'm so happy i found it again but, now of course it doesnt work I run the install for the game and it says besides some memory problems, it says ' Memory cannot be initialized ', i have downloaded the game from the site all legal and whatnot but thats what it says when I try to run the install program with all the files unzipped into a dir on c:\. Do i need to copy all the files to floppies??
Help much appreciated, by the way DEADLY site and program I thank you very much.
GIMMIE ALL YA GOT!
( Al Pachino, in HEAT )
Reply 1 of 8, by GuyIncognito
Nvr mind im an idiot, but after installation screen goes blank and no game 🙁 , just black dosbox screen?? why?
GIMMIE ALL YA GOT!
Reply 2 of 8, by Tangar
I installed the game from floppies on a virtual pc with MSDos 6.22 installed. Then I copied the installed folder to my dosbox folder. The only problem I have is that the game crashes when starting to fly a mission.
I also tried out Pacific strike, there I had an error on the VCPI memory.
Reply 3 of 8, by Tangar
Reply 4 of 8, by robertmo
Pacific Strike works in DOSBox.
To run Pacific Strike in DOSBox you have to edit dosbox.conf and set:
ems=false
after running dosbox type:
loadfix -2
you can run the game now
Reply 5 of 8, by priestlyboy
Hmm, strange. I don't have the DISK version of Strike Commander But I do have the CD Version and it actually works just fine. I wish I could be of more help.
Ieremiou
Helping Debug DOSBox.
Reply 6 of 8, by CAT Shannon
If you are still reading in here, priestlyboy could you please post your system data? I´m trying to get Strike Commander running like mad, i´m even thinking about getting the CD version but I´m just not sure if it will work.
Life is a sequence of missed opportunities
Reply 7 of 8, by Aku
hii all, priestlyboy i have got the cd version of the game. when is start installation from dosbox 0.62 it gives a error sayin '''one of the configuration files either cud not b located, or cud not b created''' and quits bak to the mounted cd-rom drive. any ideas? anyone? wud b great help 😉
Reply 8 of 8, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
@Aku: Ask DOSBOX related questions in DOSBOX forums (in this case DOSBOX Games/Apps).
Mirek
