First post, by kevin32
There are some problems I noticed in a casino game, and I have 2 questions:
1. Is there a way to force dosbox to quit when you press a key? The game does NOT allow you to quit. You can ESC to the casino's game menu, but there's no key to exit the game and quit to desktop.
2. Is there a way to make the game to animate SIMULTANEOUSLY with the music? On the game's title screen it shows the casino building and colorful lights that are supposed to flash around while the music plays. The problem is, the lights flash AFTER the music plays, when it's supposed to play at the same time. You need to slow down the CPU cycles to around 1400 to see the issue.
Thanks.
Reply 2 of 2, by Jorpho
Why not just click the "close" button in the corner of the DOSBox window?
So, don't do that, and you won't see the issue.
