A Vampyre Story
First post, by Hazekel
It is known that the first "A Vampyre Story" has problems with Windows 7 64-bit (which I have). Allegedly the problem is with the libpandadx9.dll
If you rename that file and set the anti-aliasing to 0, then quit, and then rename libpandadx9.dll back to its original name it should work ... but alas ... it does not.
Does anyone know of a way to get around this? The only graphics options available in menu is the anti-aliasing and "low lighting" option. Neither seem to have any effect one way or another. If I don't use libpandadx9.dll at all the game will never make it past the menu. If libpandadx9.dll is in the game folder then the game will not even start! Considering the game has two sequels I would think they have fixed this somehow, but I cannot find any solutions? Can anyone help?
Thanks in advance.
Reply 1 of 3, by ZellSF
Use DXGL or dgVoodoo2. Yes I know it's a Direct3D9 game, but it seems to make some calls to ddraw.dll that fails on Windows 7 anyway, that both those wrappers can handle.
You might also want to try this:
http://community.pcgamingwiki.com/files/file/ … lution-changer/
I don't actually want to play this game, but it seems to work:
The attachment test1.jpg is no longer available
But it will use different scaling than your GPU and create some glitches (visible on the image). Up to personal preference I guess, but thought it worth mentioning.
Reply 2 of 3, by Hazekel
Thanks. It is running now, albeit in a window. Will check out to see if the scaling is worth it.
Reply 3 of 3, by Lelasin
It looks really great I would like to see it with my own eyes)
This Vampyre Story somehow reminded me of another game 🤣
Probably because of the graphics 🤣 🤣 🤣
Edit by Qbix: Lets not link to sites like that.
