First post, by jade_angel
I just acquired an SR-M401-A motherboard, which seems to be an OEM rebranding of the Pine PT-432b (same jumpers, same BIOS ID strings, everything). I have managed to foul up the BIOS by being an idiot and trying to install an update for a Biostar 8433UUD (which looks almost identical but clearly is not). I have a USB flash ROM programmer, but what I don't have is the original BIOS image for the PT-432b.
Does anyone have a copy of that available? Particularly if it's newer than 10/10/94, but I'll work with anything at this point.
All this might be moot, since the board might be defective to begin with - it was hanging while loading HIMEM.SYS while booting DR-DOS, and OS/2 wouldn't boot (hung at the boot blob) - and the ill-advised reflash was part of my efforts to troubleshoot that. But, I'll cross that bridge when I come to it...
Main Box: Macbook Pro M2 Max
Alas, I'm down to emulation.
Reply 1 of 5, by Frasco
This happened to me in both situations:
- Bad RAM of course
- Using unofficial processors
Good luck. This is a bad one.
And may I join the club ?
Someone here happens to have an ASUS TX97-XV motherboard (updated to version 0112-1) ?
Reply 2 of 5, by Deksor
@Frasco I've found this : http://www.elhvb.com/mobokive/archive/Asus/so … 30tx/index.html
The -xv folder doesn't contain any bioses, but the -x does have many of them. If you're lucky, they will work just fine ^^
@jade_angel I'm not sure if there's anything interesting for you there but I've found this : http://www.elhvb.com/mobokive/archive/Pine/Di … ries/index.html
Reply 3 of 5, by Frasco
I cringe when I have to improvise something in my computers 🤣
Looks promise and I can try, now that I have an USB programmer.
Reply 4 of 5, by jade_angel
Frasco wrote:
This happened to me in both situations: - Bad RAM of course - Using unofficial processors […]
- Bad RAM of course
It might be bad RAM - I've tried 8 different sticks, both FPM and EDO, but I haven't tested all the permutations exhaustively. Of course, right now, I can't...
As for the CPU, I'm using an AMD 5x86/133, which seems to be working fine, as far as that goes.
Reply 5 of 5, by jade_angel
That's a better manual copy than the one I have, but, alas, no ROM.
I think it's just about possible that maybe the Biostar BIOS would have worked but my EEPROM is too small, or the flash process went awry, so I suppose I'll try reflashing the chip offline and see if it works.
Failing that, maybe I'll have to dig up another board like this, and I'll make sure to dump a copy of the BIOS and put it somewhere interesting.
