How much memory?
First post, by infoRM
I have a 486 DX2-66, a Diamond S3 Trio64 2mb, a SB16 CT2290 and a Creative 2x CDRom. I currently have 16mb of RAM. I want to expand the memory. I would like to know how much would be ideal, 32mb or 64mb.
Thanks, guys!
Reply 1 of 10, by Jade Falcon
Rank BANNED
BANNED
What motherboard? L2 amount?
I'd say 32mb.
Reply 2 of 10, by badmojo
8 is fine for DOS, 16 if you're running Windows 95 - why expand? If it's just for fun - a perfectly valid excuse! - then jam as much in as possible I'd say.
Reply 3 of 10, by clueless1
^This.
My DX2-66 is DOS-only and it runs everything I throw at it with 8MB.
Reply 4 of 10, by luckybob
+1 for badmojo
That said, when it comes to ram, I feel more = better.
Reply 5 of 10, by keenmaster486
Badmojo is certainly right. Maybe you'll find the very odd DOS program that needs more than 8 megs. But that would be rare, and would probably need more than a 486 anyway.
World's foremost 486 enjoyer.
Reply 6 of 10, by Matth79
If you need more than 16MB, you probably need more than a 486, in my time with 486, DOS / Win3.1 I can only recall one system needing 16MB
Reply 7 of 10, by Jorpho
Those 486 boards can sometimes be very picky about what combinations of SIMMs they will accept. You might have to take into consideration what is available to you.
Reply 8 of 10, by Errius
My 486 box has 8 MB and runs every DOS game I've tried with it. I did try putting Windows 95 on but it was painfully slow so I took it off again. I may upgrade to 16 MB but I'm not in any hurry.
Is this too much voodoo?
Reply 9 of 10, by nforce4max
8mb is enough if this is a dos build, 32mb is just for dick waving and if you end up in the position to need that much you need a socket 5/7 pentium build.
Reply 10 of 10, by infoRM
Thank you for your attention, guys. I should keep the 16mb, then.
