First post, by kva
Hi.
Mobo: Tyan S1668D
CPU: Pentium II Overdrive 333Mhz X2
RAM: 8x32MB EDO (60ns).
First run with memtest just to be sure that everything works - 114MB/s. I know that simms are not very fast but I expected more... Should I? I have run this three times, AVG speed is about this 114MB/s.
Ok, so time to go into BIOS and change some settings. I have changed everything to "high" or "fast", tighter timings. Memtest - 59MB/s 😢
I was trying to find optimal combination but I have failed to find it. The best was still the 114. Is this really maximum available value for this spec?
Celeron Tualatin vs Celeron Conroe at equal clocks
Pentium Pro 256k vs Pentium Pro 1M vs Pentium II Overdrive!
VIA C3 vs VIA C7
My website all about old hardware
Reply 1 of 2, by luckybob
memtest is not a good measurement of memory speed. I've never trusted it.
try something else like speedsys. There are threads on this form with many many examples of systems, and their speeds. For example, look at the 686 ultimate benchmark thread.
