First post, by torindkflt
I'm currently in the process of searching for a cable that I can use to connect my 486 build to a KVM switch that supports AT keyboards. A nearby "that place still exists?" RadioShack has 5-pin MIDI cables on clearance. I know the connectors themselves are physically identical, but is the wiring from end to end electrically compatible to work as a drop-in solution for AT keyboards? Or is there some sort of cross-over or disconnected pins somewhere in the middle that makes MIDI cables unsuitable for use with AT keyboards?
