First post, by zerker
So I have a (admittedly minor) issue that's been bothering me since I first picked up this game back in the 90s. The setup menu contains an option for MCGA/VGA graphics, but I've NEVER, EVER gotten this to work.
No matter what machine I am on (my original 386 and 486 machines back in the day, DosBox, the current Celeron retro machine), the game simply refuses to start and just switches to a completely blank, black screen and stays like that forever.
So, is this a known issue with this game? Were there some bad versions released to retail at some point? I noticed on MobyGames that there are VGA screenshots, so at least SOMEONE got it working. My version came with both 3.5" and 5.25" floppy disks, but I remember getting the same result no matter which I tried.
Here is the directory listing of my SPOT install folder, for reference:
 Volume in drive C is RHO
Volume Serial Number is 4852-8512
Directory of C:\GAMES\SPOT
. <DIR> 03-02-16 4:30p
.. <DIR> 03-02-16 4:30p
0 LZD 11405 05-05-07 12:44a
1 LZD 11820 05-05-07 12:44a
2 LZD 8662 05-05-07 12:44a
3 LZD 8138 05-05-07 12:44a
4 LZD 7956 05-05-07 12:44a
5 LZD 8827 05-05-07 12:44a
6 LZD 10014 05-05-07 12:44a
7 LZD 33827 05-05-07 12:44a
8 LZD 8255 05-05-07 12:44a
9 LZD 8258 05-05-07 12:44a
A LZD 8586 05-05-07 12:44a
ADLIB DVR 7840 05-05-07 12:44a
B LZD 7627 05-05-07 12:44a
C LZD 10278 05-05-07 12:44a
CMS DVR 12450 05-05-07 12:44a
CONFIG VM 3 03-02-16 5:23p
COVOX DVR 6208 05-05-07 12:44a
IBM DVR 3027 05-05-07 12:44a
MUSICDVR 8 03-02-16 5:23p
NULL DVR 188 05-05-07 12:44a
ROL DVR 1468 05-05-07 12:44a
SETUP EXE 16283 05-05-07 12:44a
SPOT EXE 343451 05-05-07 12:44a
TANDY DVR 3584 05-05-07 12:44a
26 file(s) 538163 bytes
183500800 bytes free
And yes, the game is not particularly graphically intense and runs fine in EGA mode, but it's been bothering me for entirely too long 😀
Reply 1 of 6, by leileilol
CONFIG.VM marked read only?
As far as I can tell you're not missing any files. Those 2007 dates though hmm (they should really be in a range between May and August 1990)
long live PCem
FUCK "AI"
Reply 2 of 6, by zerker
Naw, no files are read only. The dates are likely just an artifact of me coping around the same post-install version from a couple machines, including in and back out of a DosBox setup or two. Here's the listing from a fresh install from floppy:
Directory of C:\GAMES\SPOT2
. <DIR> 03-11-17 6:55p
.. <DIR> 03-11-17 6:55p
0 LZD 11405 05-29-90 11:56p
1 LZD 11820 08-16-90 5:51p
2 LZD 8662 08-07-90 8:57p
3 LZD 8138 08-13-90 5:22p
4 LZD 7956 08-13-90 1:06p
5 LZD 8827 08-13-90 1:07p
6 LZD 10014 08-24-90 3:52p
7 LZD 33827 08-12-90 1:50a
8 LZD 8255 08-19-90 3:29p
9 LZD 8258 08-19-90 3:30p
A LZD 8586 08-19-90 7:47p
ADLIB DVR 7840 08-17-90 10:46p
B LZD 7627 08-19-90 10:03p
C LZD 10278 08-19-90 10:04p
CMS DVR 12450 07-27-90 3:37p
CONFIG VM 3 03-11-17 6:56p
COVOX DVR 6208 07-10-90 5:20p
IBM DVR 3027 08-10-90 9:46p
MUSICDVR 8 03-11-17 6:56p
NULL DVR 188 08-10-90 5:04p
ROL DVR 1468 08-17-90 11:49p
SETUP EXE 16283 08-27-90 2:40p
SPOT EXE 343451 10-15-90 7:31p
TANDY DVR 3584 07-12-90 10:21p
182730752 bytes free
The re-installation was, of course, no more successful. I did a compare of the two folders for sanity's sake (thanks 16-bit Beyond Compare!), and they are binary identical -- excluding, of course, the two config files: musicdvr and config.vm because I was using different options.
Reply 3 of 6, by Ampera
Try it in DOSBox.
Reply 4 of 6, by leileilol
Tried hexing the first two bytes in CONFIG.VM to 13?
long live PCem
FUCK "AI"
Reply 5 of 6, by zerker
As I said, I have tried it in DosBox to no avail. I retested it just now to ensure I wasn't insane 😀
As for CONFIG.VM: don't you mean the first two nibbles? My config file, with VGA enabled, was written as 130202. I edited to 131302 for the heck of it, but no change.
I'm considering searching for a decompiler or something...
Reply 6 of 6, by zerker
So just to follow up, I pirated an 'abadonware' copy of my own game just to see what was up. One Beyond Compare hex editor session later and it looks like my copy of 6.LZD and SPOT.EXE differ quite dramatically from that version. It appears that there were multiple revisions of the game then. I ran the other one in DOSBOX just to confirm, and yeah, VGA works there.
.. and pirate version deleted again. I guess I'm okay with EGA 😁
