First post, by tikoellner
Hey there!
When I thought I have finally solved all the issues with my VLB controller (it already has LBA support after I flashed the newest BIOS).
I can't, however, get the floppy working properly.
First of all, I have enabled FDD support on the card itself, by bridging the appropriate jumper. But almost each time I turn on my computer, I get floppy disk fail (40). On some instances there is no such information, but then I get lots of "sector not found" errors.
I should add that in my motherboard BIOS I have selected 1.44 and 1.2 drives.
Now, I'm not sure if I should have done that - maybe this is handled by the VLB card's BIOS? The manual does not cover this. Is there any Promise products owner who have successfully connected floppy drive to the card? I just hope the card isn't broken.
Reply 2 of 2, by tikoellner
Hey, thank you.
Yes, I have tested another cables - one wit only single 1.44 connector and another with 1.44 and 1.2 connector.
This seems strange, but I get the following symptoms:
- When I connect 1.44 FDD and 1.2 FDD (simultaneously), 1.2 drive works flawlessly (read/write). 1.44 is detected (I disabled floppy drive seek in BIOS), but it generates errors.
- When I connect 1.2 FDD only, the drive does not work - it generates strange noises reading any disk and finally fails to read anything (well, I can get it to read a directory, but if I try to run anything, I get errors).
So I can't simply use any single drive - it looks like the controller requires some form of "termination".
Any ideas where it leads?
