First post, by Volfer
Hi everyone ,
I hope a kind soul that has this motherboard can help .
I recently got the famous Dual Tualatin DDR1 server board MSI Pro266TD .
But , as with almost everything in my life , it payed the proverbial piper- it suffered slight damage during CPU Cooler mount( I hate clamp-on coolers of back in the day with passion)
2 SMD resistors seem to be a bit damaged - nothing is fully detached from the board ,but I need a photo of an existing board to be able to spot the numbers - the replacement is not hard at all .
The two SMDs that got hit are located in one specific spot - Near North Clamp of CPU 1 ( bottom socket m top clamp- to the left under the MOSFET and the capacitor.
You can check it on the image .
If someone can help with this , it will be inmensly appreciated
Original image is available as attachment -just for resolution reference
Reply 1 of 1, by Rio444
Hi, is this it?
R113 is probably 201 = 200 Ohm
R87 is 01b = 1 kOhm +-1%.
